DX6i and AR 6000's
Tower Hobbies
Logged in as Guest
  Printable Version
JR R2000, JRPR2000 10CH RX, and JR Synth TX Module
Seller:  Erick Royer
Details:   $400.00   |  9/1/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> JR Radio & Spektrum Radios Support Forum >> DX6i and AR 6000's
Page: [1]
Login
DX6i and AR 6000's - 3/18/2008 1:41:00 PM
Old Goat
Status: offline
Anyone else having problems binding the new DX6i's to the old AR6000 RX?
Have spoken to Horizon tech support, they confirmed the tx and rx are compatible, and that I am trying to bind them correctly. (Binding plug and power to rx, hold trainer switch and turn DX6i on).
After trying to bind 6 different DX6i's with six different AR6000's, (yes I use a lot of radios systems for business use), only one pair bound, and that was after holding the trainer switch on for a straight 15 minutes.
Jack
www.ealeaerialimages.com
_____________________________
Visit my website
http://www.eagleaerialimages.com
       Post #: 1
RE: DX6i and AR 6000's - 3/20/2008 3:50:57 PM
Old Goat
Status: offline
Discovered that plugging servos into rx, allows system to bind much more easily. But it can still take up to 5 mins. Plus, had a couple of instances, where after removing bind plug, and switching rx off, next time system was started, the binding had been forgotton, and needed to be done again. SCARY thought if this happens in the air......
Jack
< Message edited by Old Goat -- 3/20/2008 3:51:39 PM >
Visit my website
(in reply to Old Goat)
       Post #: 2
RE: DX6i and AR 6000's - 3/24/2008 2:00:18 AM
jcatz4
Status: offline
Has anyone used the DX6i with AR6100E W/3-1 in a E-Flight Blade CX2. I can not get it to bind
       Post #: 3
RE: DX6i and AR 6000's - 3/24/2008 6:55:04 PM
hfenn
Status: offline
Hi, I just bound a 6100 (not 6100e but should work the same) to my DX6i in a Blade CP. 1-Put the bind plug in the batt port. 2-Plug in the battery on the chopper, the light will flash inside the Rx. 3-While holding up on the trainer switch, turn on the Tx. 4-The light in the Rx will flash, then go out, then come back on solid. Now you can release the trainer switch. 5-Pull the bind plug out while the power is still on the Rx. Rebind once you get all your control throws and directions sorted out. I usually do this after a trim flight to confirm all the setting are where I want them.
< Message edited by hfenn -- 3/24/2008 6:56:32 PM >
(in reply to jcatz4)
       Post #: 4
RE: DX6i and AR 6000's - 3/25/2008 12:10:36 AM
jcatz4
Status: offline
I did it that way and still does not work. I get the controls elev. and aile. to work but no throttle. the cx2 has a eflite 3in 1 control unit (mixer speed control gyro system) horizon hobby website said the DX7 works with this helicopter maybe the DX6i does not?
Thanks for your help
jeff
(in reply to hfenn)
       Post #: 5
RE: DX6i and AR 6000's - 3/25/2008 1:22:29 AM
BelAirBob
Status: offline
Before I bought a CX2, I emailed Horizon Hobby and asked if the DX6i would work. The assured me it would, but I have not bought one yet.
bob
       Post #: 6
RE: DX6i and AR 6000's - 3/25/2008 1:24:28 AM
jcatz4
Status: offline
Got it to work I reversed the throttle servo it needed to be normal
Jeff
       Post #: 7
RE: DX6i and AR 6000's - 3/25/2008 3:23:21 AM
hfenn
Status: offline
quote:
ORIGINAL: jcatz4
jeff
If you have elev. and ail control then the bind was successful. If you have no throttle first make sure the throttle channel hasn't been reversed, then check out your connections, motors and esc's. I have set up a CX2 on a friend's DX7 then his JR9303. I see no reason it won't work with the 6i.
       Post #: 8
RE: DX6i and AR 6000's - 3/25/2008 3:24:31 AM
hfenn
Status: offline
you must have been typing the same time as me lol
(in reply to hfenn)
       Post #: 9
RE: DX6i and AR 6000's - 3/26/2008 3:05:37 AM
jcatz4
Status: offline
DX6i is working with my CX2 but it has a tail wag that was not happening with the e-flite tx. I'm using an airplane program also had someone from my club try to fix it but had no luck.
(in reply to hfenn)
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.609RCU1
