HFD-08RD Problem
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Hitec/MultiPlex Radios- Ask Hitec Customer Service >> HFD-08RD Problem
Page: [1]
Login
HFD-08RD Problem - 3/19/2008 1:54:01 AM
mpaczyns
Status: offline
I a new to the hobby and attempting to build my first Extra 300s. I am having problems with getting the reciever to operate both ailerons. Do each go into a different slot on the reviever, or do I have to mount both in the same slot with some kind of 2 into 1 wire? I can get one to operate great in the channel 5 slot.
Mark
       Post #: 1
RE: HFD-08RD Problem - 3/19/2008 7:19:42 PM
MikeMayberry
Status: offline
Mark,
It all depends on your transmitter... If it is a multi channel computer radio then it will have mixing to handle the dual ailerons; this is typically the aileron differential or flapperon setting in which you will use channels #1 and another depending on the radio for the second servo. If your radio does not have mixing then you will need to use a Y harness to link the two servos to the aileron channel.
Mike.
Note: Please be aware this forum in for interaction between Hitec reps only. Please use PM if you want to offer advice to help.
_____________________________
Hitec RCD Rep
http://www.hitecrcd.com
(in reply to mpaczyns)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.289RCU1
