JR 9303 2.4 Range check
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> JR Radio & Spektrum Radios Support Forum >> JR 9303 2.4 Range check
Page: [1]
Login
JR 9303 2.4 Range check - 3/19/2008 8:45:16 AM
ravikoth
Status: offline
Hello Danny,
I have just purchased a brand new JR 9303 2.4 radio with the 921 Recvr. This has been installed in my model and during the range check, this is what i get.
With the model on the ground and the TX antenna pointing directly at the model & the bind button pressed i get about 26 steps or so and then all 3 leds on the recvr turn off completely, with 1 of them intermittent.
However if i turn slightly and the antenna is now pointing parallel to the model, all 3 leds light up and now i can go upto 40-50 steps with all leds rock solid and control surfaces operational.
I then took a flight and the radio operated perfectly with no glitches whatsoever.
There appears to a be a "null" area in the propogation of the signal, which causes the LED's to go off when the aerial is directly pointed at the model.
My question is
Is this normal?
Regards
Ravi Kothari.
       Post #: 1
RE: JR 9303 2.4 Range check - 3/19/2008 11:06:52 AM
slarty
Status: offline
Yes that is normal, which is why they always advise you to never point the transmitter antenna directly at the aircraft. Try tilting the antenna up to a vertical position and you should see an improvement.
(in reply to ravikoth)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.137RCU3
