Century Jet Retracts questions.
Tower Hobbies
Logged in as Guest
  Printable Version
Ziroli Stuka - laser lizard cut short kit - Kit
Seller:  laserlizard
Details:   $99.98   |  7/18/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> Century Jet Retracts questions.
Page: [1]
Login
Century Jet Retracts questions. - 3/19/2008 12:36:31 PM
Kawa
Status: offline
Hi,
I've got myself a pair of Century Jet Retracts (pneumatics) for my .60size P51. And I do have a couple of questions.
1.Ive pointed the "spring-knee" forward. Will that hamper the performance? I can see in other threads that people are pointing the "spring-knee" backwards (mostly).
2.I think I saw a post in here once about how to reduce the speed of the retract. Right now when I pump it up to 60psi, they slam into the gearbay with a devastating speed. Anyone know how to make them run "easier / smoother"? Like a reduction-ventile-system or something?
       Post #: 1
RE: Century Jet Retracts questions. - 3/19/2008 12:51:20 PM
u2fast
Status: offline
robart makes a restrictor. it is a small piece of brass that has a very tiny hole so only a small amount of air can pass. it goes in line between the valve and the retract. one used for up and another for down. this will help dramatically. also, i have seen some people put a wheel collar on the outside of an airline and tighten the set screw. this pinches down the line and has the same effect. same thing, install between the valve and the retract. you will need 4 total for up and down. it is easy to try. good luck, barry
(in reply to Kawa)
       Post #: 2
RE: Century Jet Retracts questions. - 3/19/2008 1:19:35 PM
Steve Collins
Status: offline
Robart also makes a retract valve that has adjustments to slow the gear down.
_____________________________
Steve Collins
(in reply to u2fast)
       Post #: 3
RE: Century Jet Retracts questions. - 3/19/2008 2:33:23 PM
Bob Yeager
Status: offline
http://www.centuryjet.com/webstore/moreinfo.cfm?Product_ID=616&CFID=378&CFTOKEN=22823881
Wyoming Windsock
"Facts are better that Bull ****"--Major Jack Reacher
(in reply to Steve Collins)
       Post #: 4
RE: Century Jet Retracts questions. - 3/19/2008 2:50:54 PM
P-47guy
Status: offline
As far as the "spring Knee" pointing forward, scale for a P-51 is for this to point aft. P-47s on the other hand point forward. I have a pair of century jet retracts in my Top Flight 60 size P-47. They work well enough when maintained. They also are a little weak. I fly off of a grass runway and they will bend if my landing is a little less than perfect.
(in reply to Bob Yeager)
       Post #: 5
RE: Century Jet Retracts questions. - 3/19/2008 3:38:56 PM
Kawa
Status: offline
Indeed thanks for all the answers - that clearifies a lot.
...need to practice more landings on realflight then
(in reply to P-47guy)
       Post #: 6
RE: Century Jet Retracts questions. - 3/19/2008 8:55:15 PM
paladin
Status: offline
If you are going to use the wheel collar method (I use a lot) the business end of the set screw is made to bit into the material in the wheel collar. If you look closely you will see the bottom of the set screw has a little cup in it. Dremel the cup ridges off and you will not get as many leaks there.
Joe
If it don't fly it wont ketch my eye.
(in reply to Kawa)
       Post #: 7
RE: Century Jet Retracts questions. - 3/21/2008 5:21:36 PM
Kawa
Status: offline
quote:
ORIGINAL: paladin
Joe
Thanks for heads up. I will go for the collar solution first (guess i might order a vent later)
(in reply to paladin)
       Post #: 8
RE: Century Jet Retracts questions. - 5/14/2008 6:34:38 PM
BOLT
Status: offline
Hello:
I need help on my Century Jet retracts but I would like to post some pictures of it and I don't know how. The pictures will help to explain the problem. Can someone help?
Blessed is the man who has a hobby for he has two worlds in which to live.
(in reply to Kawa)
       Post #: 9
RE: Century Jet Retracts questions. - 5/15/2008 2:51:54 AM
LDM
Status: offline
Kawa , I have about 10 pairs of cj retracts , I use the Robart air controler on all my CJ gear as opposed to the CJ controller .
I never ever use air restictors because in essence its waisting air pressure , by useing the robart controller , you can easily adjust the air and the gear will retract in a very scale manner . Usually the entire support kit from tank , regulator , and lines can be purchased for under $40 bucks
LDM
(in reply to BOLT)
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
Photo Gallery | Member Video Posts | RCU Video Gallery | Instructor Search | Field|Track|Marina S
