RE: King Motors Baja Review with pictures
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Giant Scale Cars >> RE: King Motors Baja Review with pictures
Page: <<   < prev  12 13 [14] 15 16 17 18 19 20 21   next >   >>
Login
RE: King Motors Baja Review with pictures - 5/20/2008 4:03:14 PM
jtnktz
Status: offline
quote:
ORIGINAL: toors
Got the clip off but cant get the plastic spur gear off!!
Also, how we stop the pinion spinning to remove it?
Piston stopper:
http://www.davesmotors.com/store/product477.html
Or some people put string down in the cylinder and jam it but I do not like the idea of putting something in my engine.
_____________________________
T-maxx///Revo///Vendetta ST///OFNA Ultra LX Comp///HPI BAJA 5B (Clone but still goes)
(in reply to toors)
       Post #: 326
RE: King Motors Baja Review with pictures - 5/20/2008 5:43:22 PM
hellya
Status: offline
quote:
ORIGINAL: jtnktz
Thats cool, so how did it work? How much total? I plan on doing a head kit and would like a black head (going stealth).
the head kit is $55, the heat sink is $99 ........then use the stock 23 cy that comes with the KM
engine started and runs great
< Message edited by hellya -- 5/20/2008 5:44:30 PM >
(in reply to jtnktz)
       Post #: 327
RE: King Motors Baja Review with pictures - 5/20/2008 7:59:33 PM
jtnktz
Status: offline
quote:
ORIGINAL: hellya
quote:
ORIGINAL: jtnktz
Thats $155 for a head kit? You could get a complete kit for that? Is it at least ported and all that fun stuff?
(in reply to hellya)
       Post #: 328
RE: King Motors Baja Review with pictures - 5/20/2008 8:53:52 PM
hellya
Status: offline
quote:
ORIGINAL: jtnktz
Thats the price for the head kit and heat sink.....now if i seize up the piston or ring I take off the heat sink, I can reuse it over and over
.the entire head kit is only $55 yes ported rated at 4hp http://www.davesmotors.com/store/product1658.html
Click to see fullsize image.
Click for fullsize
< Message edited by hellya -- 5/20/2008 8:59:49 PM >
       Post #: 329
RE: King Motors Baja Review with pictures - 5/20/2008 9:17:05 PM
jtnktz
Status: offline
quote:
ORIGINAL: hellya
quote:
ORIGINAL: jtnktz
Will it work with the CY23?
Fits CY29RC engines or other engines with +2mm stroker if the cylinder is modified or a .040" copper gasket is used.
Will I need to buy a 2mm stroker?
       Post #: 330
RE: King Motors Baja Review with pictures - 5/20/2008 9:25:22 PM
krayziedxc
Status: offline
nice upgrade..goin to have to get me one too..then. first need to sell my 2 engine and get 2 new engines
-FG BAJA
-KINGMOTOR BAJA
       Post #: 331
RE: King Motors Baja Review with pictures - 5/20/2008 10:07:22 PM
rckiwi
Status: offline
quote:
ORIGINAL: toors
If you use a new or old gear, place on the pinion and spur gears so to lock them together, then you can remove the hex screw in the pinion gear. Sometimes you have to lever the spur gear off!
(in reply to toors)
       Post #: 332
RE: King Motors Baja Review with pictures - 5/20/2008 10:33:56 PM
hellya
Status: offline
quote:
ORIGINAL: jtnkt
Yes, thats what I used the stock 23 cc CY thats comes with the KM, no stroker needed
quote:
This kit can also be used as an air cooled cylinder head, if the Darksoul heat sink is used. In this case, these top ends will also function well as replacement top ends for Zenoah G230RC/G260RC, and Chung Yang CY23RC/CY26RC/CY27RC/GP290
< Message edited by hellya -- 5/20/2008 10:40:09 PM >
       Post #: 333
RE: King Motors Baja Review with pictures - 5/20/2008 11:13:41 PM
u9511160
Status: offline
I am terribly disappointed.
My KM baja arrived today and from what I can see the quality is not even close to the real thing. To be honest and fair - it's a piece of crap and a cheap clone.
Things that I have seen until now:
1. Shocks are so bad that they leak. Until now I have rebuilt one, and this is what I found: It was half empty when i got the buggy. It was filled with some kerosene smelling oil, instead of silicone. The parts quality is very bad. It's not even close (except for size and shape) to the real thing in quality. The shock does not have any orings. It only has one thick gasket that cannot hold 25wt oil inside. Shocks don't have HPI adjust technology. It's just a thick piston with two very small holes.
2. Some screws were stripped (one on the rear arm, one on the front arm) (i've removed 8 screws until now, 2 were stripped).
3. Some of the screws/nuts were already rusted.
Guys, please tell me if anyone of you opened the shocks up. Are they how I described or close to the real thing?
Thanks.
       Post #: 334
RE: King Motors Baja Review with pictures - 5/20/2008 11:42:38 PM
hellya
Status: offline
you sure you got a km or the km clone??
my clone moves have had no issues.....I own a SS too
< Message edited by hellya -- 5/20/2008 11:44:14 PM >
(in reply to u9511160)
       Post #: 335
RE: King Motors Baja Review with pictures - 5/20/2008 11:43:48 PM
rckiwi
Status: offline
quote:
ORIGINAL: u9511160
Thanks.
Yes that is correct they do not have the adjuster system that the Gen baja has in the shocks, but of course you can fit gen replacement shock kits if you want, and even better replace with the up graded 6mm shaft type.
You must remember with any "Copy or Clone" it will not be the same as the original! and the price of a KMS baja really says that! the money you have saved can be spend fitting up grade parts that you want to! and really when you look at all the companies selling up grade parts for the Gen baja do you think that is 100% good?
       Post #: 336
RE: King Motors Baja Review with pictures - 5/20/2008 11:47:39 PM
hellya
Status: offline
I wonder why most of the HPI baja owners up grade their shocks to phattys is it because the stock shocks are great.....No they suck
Thats one of my first upgrades I did on my HPI SS ....phattys and wheel extenders....Open your wallet...welcome to the money pit that all 1/5 hobbiest have fell into
heres a HPI Baja bent shock
< Message edited by hellya -- 5/21/2008 12:22:54 AM >
(in reply to rckiwi)
       Post #: 337
RE: King Motors Baja Review with pictures - 5/21/2008 1:45:30 PM
u9511160
Status: offline
I have the KM baja - from v*tec.
I have drilled the shock pistons trough the existing holes with a 1mm drill. I am using 25wt in the front, 35wt in the rear. I was lucky to find 4 orings in my pit box. I used those to create better seal.
Are u guys sure that the HPI shock piston parts (85412) are compatible with these shocks?
Edit: Noted that the pull-start doesn't have a metal recoil ring as some of you have.
< Message edited by u9511160 -- 5/22/2008 4:55:54 PM >
       Post #: 338
RE: King Motors Baja Review with pictures - 5/23/2008 9:12:43 AM
hellya
Status: offline
Anyone want a KM baja......want it today???....Go to walmart Seriously...talk about distribution thats alot more exposure than Hpi will ever get.
The market will flood
< Message edited by hellya -- 5/23/2008 9:20:04 AM >
       Post #: 339
RE: King Motors Baja Review with pictures - 5/23/2008 9:20:55 AM
rckiwi
