RE: King Motors Baja Review with pictures
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Giant Scale Cars >> RE: King Motors Baja Review with pictures
Page: <<   < prev  14 15 [16] 17 18 19 20 21 22 23   next >   >>
Login
RE: King Motors Baja Review with pictures - 7/6/2008 3:57:42 AM
bentley marshall
Status: online
could be one of the bolts that hold the clutch shoes on has come undun and rubing on the clutch bell..... can you push
the car freely with out the engine running ????
(in reply to DarkFire989)
       Post #: 376
RE: King Motors Baja Review with pictures - 7/6/2008 9:20:59 AM
Bratch96
Status: offline
quote:
ORIGINAL: DarkFire989
Im having a problem with my throttle set up right now. I cant seem to find a nuetral at idle, it always wants to take off from me when I start it up. My uncle and I tried to fidle with it today but could not figure it out. Any sugestions?
If you can't get it to idle slower than maybe a cheap fix would be to get an 8,000 rpm clutch spring.
Most people like these as an upgrade anyway. Keep us informed.
_____________________________
Large Scale Hobby = Time Well Spent.
       Post #: 377
RE: King Motors Baja Review with pictures - 7/6/2008 3:44:08 PM
DarkFire989
Status: offline
The car can roll freely when I push it on the ground. And I was thinking about buying the other clutch.
Clod Buster | Sludge Hammer | Blue Streak | Revo | KM Baja
(in reply to Bratch96)
       Post #: 378
RE: King Motors Baja Review with pictures - 7/11/2008 3:34:52 AM
cherokee_140
Status: offline
It is hard to find a site that has an open discussion on the KM BAJA...this is refreshing.
I am thinking about getting one of these, I just can't justify $1000 for a HPI. How are they holding up? Some of the long time owners please chime in and give us some updates.
thanks
       Post #: 379
RE: King Motors Baja Review with pictures - 7/11/2008 3:55:03 AM
Bratch96
Status: offline
I don't suspect you clutch. But most likely your carburetor.
       Post #: 380
RE: King Motors Baja Review with pictures - 7/11/2008 4:00:50 AM
Bratch96
Status: offline
quote:
ORIGINAL: cherokee_140
thanks
I'm enjoying mine. I have ran several tanks of gas through it already. There are some upgrades needed.
(in reply to cherokee_140)
       Post #: 381
RE: King Motors Baja Review with pictures - 7/11/2008 4:13:50 AM
rckiwi
Status: offline
Well I have had mine for awhile and not had any problems other than the usual which happens to the Gen Baja as well,
Replaced the following, because either damage or just up graded!
Bent rear shock shafts.
Clutch assy and 8000rpm spring
Clutch bell, and carrier
Ramtech front alloy shock tower
Phatdaddy rear shock brace
HD dogbones
replaced steering servo with Hitec HS-5745MG (awesome servo) and 13kg throttle/Brake servo
Outerwears pullstart & aircleaner filters
At the moment I have de-anodized all the alloy but not sure if going to re-anodize or polish everything.
I will be making a few more up grades while apart as well.
SS diff assy (nothing wrong with original diff)
SS front and rear shock shafts
OutLaw RC HD F&R springs
Zenoah 23cc engine
Dom Side pipe
The money you save on buying one of these gives you alot to play with to up grade, but I suggest just do what needs doing!
Hope this helps.
       Post #: 382
RE: King Motors Baja Review with pictures - 7/11/2008 1:47:48 PM
cherokee_140
Status: offline
Thanks, I have read just about everything I can find on them, US sites, UK sites, I even found some info in German on them...all say the same thing....execpt for the normal anti clone garbage. So I am going to order one before the end of day today. I am already looking at items like filters and a fail safe before it ever is started.
The radio seems to be the only true weak link in the line up, I have read that there is a new radio shipping with them, are these radios worth using?
Thanks again
(in reply to rckiwi)
       Post #: 383
RE: King Motors Baja Review with pictures - 7/11/2008 2:01:05 PM
beckiesbajas
Status: offline
I sell these things in australia and the stock km baja radio offer better range then my spektrum dx2 or dx3it not bad and offers some better features the then stock hpi radio imo
Owner of BENCKIESBAJAS specialising in bashing the snot out of kingmotor bajas. Australian business number 72403022684
       Post #: 384
RE: King Motors Baja Review with pictures - 7/12/2008 3:12:07 AM
Bratch96
Status: offline
The stock radio is fine. But when I first put batteries in the tx, I noticed a gap between them, because they fit in there so tight, so I picked off these little tab things that hold the batteries in and I have not had a problem with it.
That might not make sense when you read it, but I mean that the springs that the batteries push against were compressed without even having all of the batteries in it yet. You'll see what I mean....I wonder if the horror stories about this radio gear is because of this.
(in reply to beckiesbajas)
       Post #: 385
RE: King Motors Baja Review with pictures - 7/14/2008 6:35:28 PM
boxingJay
Status: offline
im running my new km baja for the first time tonight anybody know what ratio i should mix my gas ,i am new to gas powered buggies
< Message edited by boxingJay -- 7/14/2008 6:36:58 PM >
       Post #: 386
RE: King Motors Baja Review with pictures - 7/14/2008 6:43:40 PM
Lars from Norway
Status: offline
4 % oil,this means on 5 liter gas you shall have 2 dl of oil.I dont know what this is in gallon
What seems to be the officer,problem?
Got all under cnotrol!
(in reply to boxingJay)
       Post #: 387
RE: King Motors Baja Review with pictures - 7/14/2008 6:56:17 PM
boxingJay
Status: offline
ok thanks alot
(in reply to Lars from Norway)
       Post #: 388
RE: King Motors Baja Review with pictures - 7/14/2008 7:42:58 PM
Bratch96
Status: offline
quote:
ORIGINAL: boxingJay
25:1 5.12 oz of oil per gallon.
