hellya
WA, USA Status: offline
quote:
ORIGINAL: krayziedxc thank you, i was wondering where i can get the coleman fuel..no sh*t i i got yelled at for that smell of gas in room.. how much is it for 1 gallon? Depending on where you live $4-5 a gallon quote:
ORIGINAL: boatcapt So, are these as fast as the HPI's. OK Guys heres a good hop up for cheap.....15-20 mins work. Take the exhaust tube off the stock exhaust can (just this alone will help your low end improve).... remove the stock can... inside the can is wire mesh.... remove the wire mesh. under the wire mesh is stuffing used to muffle the can remove everything and reinstall the can..... you will see a nice power difference
< Message edited by hellya -- 4/29/2008 3:49:40 AM >
