RE: King Motors Baja Review with pictures
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Giant Scale Cars >> RE: King Motors Baja Review with pictures
Page: <<   < prev  96 97 [98] 99 100 101 102 103 104 105   next >   >>
Login
RE: King Motors Baja Review with pictures - 6/20/2009 12:25 AM
ZX9RBART
Score: 100
Last Login: 11/8/2009
Status: offline
quote:
ORIGINAL: ridersstore
does any body no what the hp rating is on the km baja 29cc. and also i thrashed mine today and now the rear end feels like it has a posi unit in it now? it doesnt feel like a open diff any more? any body have this problem with ther diff?
Sounds like you trashed your diff, for a replacement i would go with the hpi baja ss alloy diff.
Hide Signatures
(in reply to ridersstore)
       Post #: 2426
RE: King Motors Baja Review with pictures - 6/20/2009 4:50 AM
ridersstore
Score: 100
Last Login: 7/17/2009
Status: offline
 this is probably a dumb question , but what does the fail safe in the km baja do ,and how do you test it?  i have the 29cc version that danic4 sells.. i love it so far
_____________________________
I LOVE MY 29CC KM BAJA
Hide Signatures
(in reply to ZX9RBART)
       Post #: 2427
RE: King Motors Baja Review with pictures - 6/20/2009 5:22 AM
KeithjV
Score: 120
Status: online
So which would you guys says is the better truck the King Motor or the Rovan Sport? Im interested in the 5T version.
Hide Signatures
       Post #: 2428
RE: King Motors Baja Review with pictures - 6/20/2009 5:53 AM
ZX9RBART
Score: 100
Status: offline
The failsafe places the servos in a preset position (programmed by you) if the signal from the radio is lost. To test, WITH THE ENGINE OFF, hold the throttle wide open and shut off your transmitter, the servos should go to your preset position, usually full braking.
Hide Signatures
       Post #: 2429
RE: King Motors Baja Review with pictures - 6/20/2009 11:33 AM
hndaman1
Score: 100
Last Login: 11/5/2009
Status: offline
quote:
ORIGINAL: TheMightyImp2
 thanks!
I have set back to factory settings..
i wonder if it's because there is dirt in the carb.
the inner and outer air filter were thick with dust from the dry parkland i run it on...
So, the run time everyone talks about of 40 mins on a tank of gas.. Will the car keep on running continuously if i keep filling it up? Or do they overheat and need a rest?
outwears my friend, and clean them filter more often..be sure to use a hi tach foam filter oil on the inner filter like "PJ1" for motor cross bikes and get an outwears it helps also
owner of R&R Racing enterprises
" Never Rub another Mans Rhubarb"
Hide Signatures
(in reply to TheMightyImp2)
       Post #: 2430
RE: King Motors Baja Review with pictures - 6/20/2009 12:44 PM
ridersstore
Score: 100
Status: offline
thanxs zx9rbart , i tried it and thats exactly what it did,, thankxs for the info.!!!
Hide Signatures
       Post #: 2431
RE: King Motors Baja Review with pictures - 6/20/2009 5:40 PM
Kostenko
Score: 101
Last Login: 11/7/2009
Status: offline
Well its simple Keith,
There's still no KM1000 as they call their 5T Truck so the only option for a cheap one is easy.
Rovan looks pretty nice...how do i know? i have two kitt versions here...
HPI Baja 5T - Futaba 4pk
Hide Signatures
       Post #: 2432
RE: King Motors Baja Review with pictures - 6/20/2009 5:48 PM
hndaman1
Score: 100
Status: offline
quote:
ORIGINAL: Kostenko
pics,pics,pics...
Hide Signatures
(in reply to Kostenko)
       Post #: 2433
RE: King Motors Baja Review with pictures - 6/20/2009 5:59 PM
KeithjV
Score: 120
Status: online
They make the 5T in a kit version?
Where did you order yours from?
quote:
ORIGINAL: hndaman1
quote:
ORIGINAL: Kostenko
pics,pics,pics...
Hide Signatures
(in reply to hndaman1)
       Post #: 2434
RE: King Motors Baja Review with pictures - 6/21/2009 9:17 PM
TheMightyImp2
Score: 100
Last Login: 7/22/2009
Status: offline
 I'm thinking someone should start a 5T thread!
Hide Signatures
(in reply to KeithjV)
       Post #: 2435
RE: King Motors Baja Review with pictures - 6/22/2009 4:57 AM
Edinator
Score: 100
Last Login: 10/18/2009
Status: offline
Hey guys, I'm really new to this hobby. My dad just bought me a King Motors Baja It's the KSRC-001. I read through the first part of the thread but I couldn't find anything about my question. This might be because it's a later version but my Baja has orange alloy and purple alloy. I'm just wondering if this is the same thing as what you guys have or if it is updated.
Hide Signatures
       Post #: 2436
RE: King Motors Baja Review with pictures - 6/22/2009 5:14 AM
BigGrump
Score: 100
Status: offline
I really do not know what is new or not from the color scheme, mine is mostly chrome and black.   I can tell you the KM Baja is not perfect, but is a lot better than what the HPI baja owners let on.
My advise is simply to apply your hobby skills, which you should have before getting a model like this, set it up as best as you can then have fun.   Expect some things to go wrong, fix them.  Pretty soon you will  find out the KM is actually well made (for the most part) and is fun.    All of the Baja's are very expensive over time.  You will end up spending a lot more money than any 1/8 scale nitro truck or truggy.
The money you save using gasoline over nitro seems like it would be a lot, but it is nothing compared to replacment parts and upgrades.   It is easy to get carried away and spend thousands of dollars on a baja if you want all the greatest aftermarket parts.  Then when you crash around and break parts, it gets really expensive.   So, just have fun with the KM and use it as you can afford.  It is not as good as a real HPI baja, but not nearly as bad as the HPI fans say.   I got a lot of good use from the stock engine, and upgraded it just for the fun of it when it was not necessary.
Dennis
Hide Signatures
(in reply to Edinator)
       Post #: 2437
RE: King Motors Baja Review with pictures - 6/22/2009 5:27 AM
Edinator
Score: 100
Status: offline
I have a local hobby store that also sell RC car parts so I may be spending more then I want to on this thing haha. I'm going to burn it in tomorrow, hopefully I won't have any major problems.
Hide Signatures
(in reply to BigGrump)
       Post #: 2438
RE: King Motors Baja Review with pictures - 6/22/2009 5:39 PM
BigGrump
Score: 100
Status: offline
You really should not have any major problems, but don't be suprised with a few minor problems.
Dennis
Hide Signatures
       Post #: 2439
RE: King Motors Baja Review with pictures - 6/22/2009 5:46 PM
Edinator
Score: 100
Status: offline
I went out to burn it in today and it ran really well for what I know about RCs. What do you recommend to do to clean the Baja afterwards. It's just got a lot of dirt and grass in the cracks and whatnot. I'll have some pictures up of the weird colours my Baja came in.
Hide Signatures
       Post #: 2440
RE: King Motors Baja Review with pictures - 6/22/2009 5:50 PM
ridersstore
Score: 100
Status: offline
your going to love it,,here is some pics of my krc002  km baja 29cc version with pipe,, i got it a week ago and already ran a gallon plus thru it and its still running strong
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 2441
RE: King Motors Baja Review with pictures - 6/22/2009 5:58 PM
Edinator
Score: 100
Status: offline
Wow nice, I really like that roll cage!
Here is my Baja KSRC-001
< Message edited by Edinator -- 6/22/2009 6:01 PM >
Hide Signatures
       Post #: 2442
RE: King Motors Baja Review with pictures - 6/22/2009 6:08 PM
ridersstore
Score: 100
Status: offline
very nice,, and you say it came that way with the diffrent colors?  if so cool,, how does she run! i now mine is insane, wheelies on camand, just massive torqe with th 29cc,,  have fun, and just a helpfull hint, get outerware cover for the pull start, and a pre filter for it.. it will last much longer..
Hide Signatures
       Post #: 2443
RE: King Motors Baja Review with pictures - 6/22/2009 6:11 PM
champ48
Score: 101
Status: offline
For cleaning I would recommend nitro cleaner and compressed air. And a tad bit of wd40 to polish her up after. The wd40 will attract a dirt though. Also "gunk engine degresser" works great to get rid of stuff stuck to your engine.
This is my baja in the photo...
Click for fullsize
Check out my channel some time:http://www.youtube.com/user/RClimits
Hide Signatures
       Post #: 2444
RE: King Motors Baja Review with pictures - 6/22/2009 6:14 PM
champ48
Score: 101
Status: offline
I don't know if you know this or not but you can remove the exhaust end for more power and it will be louder. Don't know if you knew that or not.
quote:
ORIGINAL: Edinator
< Message edited by Lightfoot -- 6/22/2009 6:48 PM >
Hide Signatures
       Post #: 2445
RE: King Motors Baja Review with pictures - 6/22/2009 6:19 PM
TheMightyImp2
Score: 100
Status: offline
 Hi there!
Is your radio good? I had to bin mine and get a Futaba 2PL, as my stock radio kept sending out a full throttle signal.
Also, if it hasn't already got one, buy a failsafe. It will save you a fortune if it goes out of control or range!
Hide Signatures
       Post #: 2446
RE: King Motors Baja Review with pictures - 6/22/2009 6:20 PM
Edinator
Score: 100
Status: offline
Thanks for the help guys! Looks like i'll have to pick up some supplies. It's running great right now. It could use a little tuning, but nothing seems to be broken and everything is fine.
I forgot to mention that I have another muffler for it. I think it is a clone of the dominator pipe. I don't know how loud it will be but hopefully it won't piss off the neighbours.
Hide Signatures
(in reply to champ48)
       Post #: 2447
RE: King Motors Baja Review with pictures - 6/22/2009 6:22 PM
Edinator
Score: 100
Status: offline
 Hi there!
Ya I tested the range and I can get around 180 meters. But the radio is fine for now. I was thinking about getting a fail safe, i'll check it out at my local hobby store.
Hide Signatures
       Post #: 2448
RE: King Motors Baja Review with pictures - 6/22/2009 6:33 PM
champ48
Score: 101
Status: offline
Do you have a Turbo Racing Digital Radio and your baja?
Hide Signatures
       Post #: 2449
RE: King Motors Baja Review with pictures - 6/22/2009 6:40 PM
Edinator
Score: 100
Status: offline
I don't know what that is but I think it is just the stock radio.
< Message edited by Lightfoot -- 6/22/2009 6:49 PM >
Hide Signatures
       Post #: 2450
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.282RCU1
