mmattockx
AB, CANADA Status: offline
quote:
ORIGINAL: Stickbuilder In addition to running the grain in a vertical orientation, I also cut a groove spanwise in the spars that will be shear webbed, and actually make the spar set an I beam. It takes a whild longer, but the strength gained is worth the effort. Bill, AMA 4720 WACO Brotherhood #1 Bill, Your craftsmanship is superb (your Waco's are incredible), but I have to tell you there is no significant strength gained by doing that. There is a very small amount gained because the I-beam shape is symmetrical and the C shape is not, and this can cause a bit of warping at large deflections. This is not an issue for our aircraft because they do not fail due to elastic buckling, they fail due to tensile/compressive overload of the material. IMO, the greater gluing area that comes from lapping the shear webs onto either of the spar faces is more important than the assymmetrical shape of the C. If you want really bombproof spars, use thinner shear webs and put one on both the front and rear spar faces to make it a box cross section. Less work than slotting, symmetrical section and improved properties all around with a tiny weight gain. Mark
_____________________________
Waco Brotherhood #4
