KevenLS
FL, USA Status: offline
Well guys i've been following this thread since it started....... I've got the 25% also maiden flight was 6/7/08 went awesome...... I am running 645 all servos except throtle servos is standard, power plant is a 45cc ftl 20-10 prop, 7.4 2600mah lith lion with 6 volt regulator, running ignition is 4.8 2500 mah bcma I set my cg at factory 142mm She flyies like a charm got three flights in today 6/8/08 engine is on third tank of gas. plenty of power can hover at just under 1/2 power and verticle is unlimited.... I would recommend this plane to anyone great looking bird Landing this bird is nice and gentle Can't beat this set up for $800.00 Now i'm ready to start my 30% yak 55 sp that i've had sitting around for 5 months!!!!!!!!!!! Maineflyer sorry about what happened hope you get it back in the air soon thanks for the build thead you did a great job!!!!!!
