FallDownGoBoom
WA, USA Status: offline
Chris: Great build so far. Your work is admirable. I built one of the little Bronco's a couple of years ago and put quad flaps on it. Rather than using torque rods, I combined the way the Top Flight Bonanza and Wing B-25 approach their flaps. I ran 4 flex cables through the ribs, one for each flap, with a 90* bend so that the cables come out perpendicular to the flap leading edge (that's from the Wing, you can see the rudiments if you go to Artazlin.com and look at his B-25 builds). Fabricated a control horn out of 1/16 ply and build it into the leading edge of each flap (you can look at the Bonanza construction manual online for details.) Soldered a clevis to the end of each cable, then connected that to the control horn. That way the flap controls are invisible when the flaps are up. At the other end of the four cables, a JR 537 was buried in the shear web in the center of the wing. I put easy connectors on each side of the servo control horn, and then connected two cables from each side onto the control horn. That way the flaps get "pushed" down and pulled up. On the little Bronco one 537 was sufficient... I'd probably do two servo's on your big one, one for each side. Just an idea. Fred
