ByronF
ON, CANADA Status: offline
This past weekend it rained so couldn't go flying and couldn't cut the lawn or wash the boss lady's car. Ho hum what to do. I know lets do some work on the Hurricane. Well after a fair bit of sanding of the ply brace and the right wing panel I was finally able to get the gap closed well enough that I could glue the wing together. Then installed the aileron servos. Went to do the flaps and on both sides the tubes for the joiner wire for the split flaps did not line up. So now I have to cut the tubes out on the outside flap on both wings, insert the joiner and then re-glue the copper tube in the new location. No big deal but more work than I wanted to do. I want to fly this thing this season before the weather gets bad so I may just tape the flaps closed, fly it and repair it over the winter. Now starting on the fuse, got the tailwheel installed and getting ready to do the stab. Don't like the idea of using CA as suggested in the manual so have to figure out how to get (enough) epoxy in there. Need to give that some thought. Must say the manufacturing tolerances on this VQ plane are pretty tight. Does not sound like a lot of progress I know but I was repairing 2 other planes at the same time so I got a little distracted. Will try and get some photos to post. Don't want to disappoint anyone but I am doing this Hurricane completely stock and with fixed gear. I have had enough of mechanicals on my H9 planes and am not prepared to spend money on airs for this plane until I know how it flys and maybe not even then. If it flys well then I will probably leave it that way and use it as my everyday flyer. The one thing I am waffling on is engine. Was initially planning on a 2C - HB61 but it does not like to be inverted. So now am considering a 4C and was looking at the Magnum that Tomas sells. Anyone have any experience with these motors. Are they any good? How do they compare to Saito or OS? Would appreciate any comments. Byron
< Message edited by ByronF -- 9/9/2008 3:43:37 AM >
