RE: Engines Comparison
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: Engines Comparison
Page: <<   < prev  1 [2]
Login
RE: Engines Comparison - 3/28/2008 7:15:21 PM
asmund
Status: offline
The ASP XL 120 AR is competitive with the AX 120. It is cheap and when fitted with the GMS 120 muffler it is only 1 oz heavier than the AX. I know this because I own the ASP and "yallaair" owns the AX and we have compared them extensively (we are neigbours)
We get the exact same tach readings on all tested props.
I was also interested in the SK 130, but got the ASP 120 instead because my research reveled that the SK would be quite alot heavier.
I still want one though, just because I like to compare different engines
(in reply to yallaair)
       Post #: 26
RE: Engines Comparison - 3/28/2008 8:41:08 PM
liquid_TR
Status: offline
yallair, which brand did you use for the 16x6 and 17x6? JXF Black or APC?
Im getting ~8200 rpm max with MenZ 17x6 on my 120AX. OS F plug, 15% nitro, head shim and baffle in place, all stock. Incredible power + transition and It pulls like a joke!
_____________________________
LiQuid TR
(in reply to asmund)
       Post #: 27
RE: Engines Comparison - 3/28/2008 10:44:06 PM
yallaair
Status: offline
Hi!
With the Volk 17x6, I get 8500 RPM peak RPM. For 3D flying and peak performance out of hover, I have to go 200-300 RPM rich on the ground. Haven't done any static thrust measurements.
Darn the ground..... and the jumping trees
(in reply to liquid_TR)
       Post #: 28
RE: Engines Comparison - 3/29/2008 1:12:12 AM
alfredbmor
Status: offline
I think that those are very respetable readings from a two stroke engine, I suppose that if I do not do any mod (Headshim and baffle) I should expect ~200 rpm less.
Saito Club Member
       Post #: 29
RE: Engines Comparison - 4/28/2008 9:42:46 PM
alfredbmor
Status: offline
Which prop do you recomend to break in an OS 1.20 AX (I have just ordered from Tower) ?
I also ordered a 16 x 8 APC prop. that I am thinking to use with my CG Ultimate
Saito Club Member
(in reply to alfredbmor)
       Post #: 30
RE: Engines Comparison - 4/30/2008 1:47:51 AM
ShortField
Status: offline
I'm turning An APC 17x4 with my AX 120 and I get a static run up of 9200 rpm's it's pulling my Wild Stik with authority
Click to see fullsize image.
Click for fullsize
RunWay? What RunWay??
       Post #: 31
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.328RCU1
