ADJ REGULATOR?
Tower Hobbies
Logged in as Guest
  Printable Version
Scale Mustang Air Filter Cover Kits
Seller:  tony-howard
Details:   $6.00   |  7/5/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Smart-Fly (Quest Engineering) Support Forum >> ADJ REGULATOR?
Page: [1]
Login
ADJ REGULATOR? - 3/20/2008 11:41:52 PM
YORAM1955
Status: offline
I received a Smart-Fly product called ADJ REGULATOR. I got it without any instructions. It is a board packed in a yellow heat shrink, with a heatsink, and 4 cables, a 2 wires with a frmal connector, a 3 wire with a female connector, a 2 wire with male connector and a 3 wire with a male connector. On the side of the unit there is a 3 pins connector. The label says " Smart-Fly - Adj Regulator - Vin<13V Vout 5.2-6.7V - 12 Watts Revision F".
What is the function of the unit ? (Iguess a regulator), what are all the cables for? what is the side connector for? where can I find instructions for this unit?
Yoram
       Post #: 1
RE: ADJ REGULATOR? - 3/20/2008 11:48:56 PM
rrritchey
Status: offline
Hi Yoram.
Its and adjustable regulator that supports a failsafe switch. E-mail us at info@smart-fly.com and we cam e-mail you the instructions.
_____________________________
Robert Ritchey
Owner, Smart-Fly
(in reply to YORAM1955)
       Post #: 2
RE: ADJ REGULATOR? - 3/20/2008 11:58:37 PM
YORAM1955
Status: offline
Just did, 7 minutes and 4 seconds, the fastest response I ever got on any support issue from any vendor.
Yoram
(in reply to rrritchey)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.266RCU1
