liquid_TR
Joined: 4/8/2007 From: ISTANBUL, TURKEY Status: offline
Dave, his problem seems to be mechanical, not related to rust. Ive also suffered a SKF 6903 bearing failure on my saito 100, as it had just 10 tanks of flight on it. (I use castor oil in my fuel). One of the balls disintegrated on the last start of the day. Fortunately I immediately shut it down to prevent further damage. The bearing was a little loose to my liking before installation. Now Ive got a nice NSK 6903 with nearly zero radial play and things are fine again.. m ofoshee; choose a bearing with a minimal radial play and balance your props at the tip and at the hub. Using 3 to 5 % castor oil in the fuel will help protect your rear bearing against rim and cage rust, and you wont need to put any mineral based after run oil at the end of the day; if you run your 125 at least once every 2 weeks.
< Message edited by liquid_TR -- 3/21/2008 11:28:02 AM >
_____________________________
LiQuid TR
