Saito 125 engine bearing failure
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> Saito 125 engine bearing failure
Page: [1] 2   next >   >>
Login
Saito 125 engine bearing failure - 3/21/2008 4:01:39 AM
mofosheee
Status: offline
Hi All:
Runnng a new Saito 125 with a 16X6 APC prop. Experienced two consecutive engine bearing failures after going thru 1 gallon of 20/20 power master. Running on the rich side and applying generous amounts of after run oil after the flying day.............any thoughts. Thank you.
       Post #: 1
RE: Saito 125 engine bearing failure - 3/21/2008 4:12:52 AM
Flyboy Dave
Status: offline
.....if you use a fuel with castor oil you will not have bearing failures.
FBD.
_____________________________
An engineer says.... "That won''t work".
A mechanic says..."Oh yeah, watch this".
"Old Age, and Treachery will overcome youth and skill".
Revver Bro #4.
(in reply to mofosheee)
       Post #: 2
RE: Saito 125 engine bearing failure - 3/21/2008 4:18:42 AM
w8ye
Status: offline
Do you balance your props
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Club Saito Member #7
Original AMA #31261
(in reply to Flyboy Dave)
       Post #: 3
RE: Saito 125 engine bearing failure - 3/21/2008 11:19:04 AM
liquid_TR
Status: online
Dave, his problem seems to be mechanical, not related to rust.
Ive also suffered a SKF 6903 bearing failure on my saito 100, as it had just 10 tanks of flight on it. (I use castor oil in my fuel). One of the balls disintegrated on the last start of the day. Fortunately I immediately shut it down to prevent further damage. The bearing was a little loose to my liking before installation. Now Ive got a nice NSK 6903 with nearly zero radial play and things are fine again..
m ofoshee; choose a bearing with a minimal radial play and balance your props at the tip and at the hub. Using 3 to 5 % castor oil in the fuel will help protect your rear bearing against rim and cage rust, and you wont need to put any mineral based after run oil at the end of the day; if you run your 125 at least once every 2 weeks.
< Message edited by liquid_TR -- 3/21/2008 11:28:02 AM >
LiQuid TR
(in reply to w8ye)
       Post #: 4
RE: Saito 125 engine bearing failure - 3/21/2008 4:02:26 PM
mofosheee
Status: offline
Thanks Guys............
The props were balanced
I'll try the 3-5% castor oil.
NSK bearings!
(in reply to liquid_TR)
       Post #: 5
RE: Saito 125 engine bearing failure - 3/21/2008 5:49:06 PM
Ed Cregger
Status: offline
That little bit of castor oil in the fuel does make a difference when it comes to ball bearing life.
Ed Cregger
Artisan
"Flying models since the Fifties - I'll get the hang of this yet!!!"
       Post #: 6
RE: Saito 125 engine bearing failure - 3/21/2008 11:10:06 PM
mofosheee
Status: offline
Despite all the warnings from Saito & Horizon about not attempting a repair on the Saito's, I have decided to replace the bearings myself (with ceramics) rather than send the engine to Horizon and wait up to 3 weeks for a return. Repairing these engines is quite simple. Thanks all!
This forum continues to be a great resource.
       Post #: 7
RE: Saito 125 engine bearing failure - 3/22/2008 2:44:14 AM
XJet
Status: offline
Make sure you don't spend more than you need to on those ceramic bearings. Go to RC-Bearings and you'll find an excellent product at a stunningly low price.
Plus the customer-service is second to none!
When I'm not here, I'm at RCModelReviews
       Post #: 8
RE: Saito 125 engine bearing failure - 3/23/2008 3:25:50 AM
mike early
Status: offline
quote:
ORIGINAL: liquid_TR
What exactly does this mean?
I have 3 gallons of Wildcat 20/20 and do not want to let it go to waste, so is it a good idea to add an extra 2% of Castor? Where does one buy Castor alone?
Thanks!
       Post #: 9
RE: Saito 125 engine bearing failure - 3/23/2008 3:27:39 AM
mike early
Status: offline
How does one know a bearing has gone bad
(in reply to mike early)
       Post #: 10
RE: Saito 125 engine bearing failure - 3/23/2008 3:28:18 AM
Flyboy Dave
Status: offline
....buy castor at the motorcycle shop.
FBD.
Revver Bro #4.
       Post #: 11
RE: Saito 125 engine bearing failure - 3/23/2008 5:50:32 AM
XJet
Status: offline
quote:
ORIGINAL: Flyboy Dave
FBD.
But be careful, some castor (usually sold for bikes or karts) is designed solely for mixing with gasoline and won't mix with methanol very well at all.
       Post #: 12
RE: Saito 125 engine bearing failure - 3/23/2008 5:57:07 AM
Flyboy Dave
Status: offline
....there is only one type of castor oil available on Planet Earth....
....this oil will mix with gasoline (petrol) or methanol....just fine.
FBD.
Revver Bro #4.
(in reply to XJet)
       Post #: 13
RE: Saito 125 engine bearing failure - 3/23/2008 8:28:00 AM
liquid_TR
Status: online
castor (correct me if Im wrong) have a hard time mixing with very high concentrations of Nitromethane - which the fuel mfgs use chemical suspensers in the mix to hold them nice and mixed.
Balancing the prop at the hub means, after balancing the prop at the tips, you can put the prop to a 13:00 - 19:00 position on a sensitive balancer such as dubro balancer, and watch which way it sways. accordingly, add some weight to the light side of the hub (center). This usually goes for only wood props.
LiQuid TR
       Post #: 14
RE: Saito 125 engine bearing failure - 3/23/2008 9:18:47 AM
mike early
Status: offline
FBD.
Can I assume this, and stuff like it, are 100% castor?
This stuff can be found at vitamin stores:
Thanks!
Edit: I see that medicinal castor is undesirable.
< Message edited by mike early -- 3/23/2008 9:49:16 AM >
       Post #: 15
RE: Saito 125 engine bearing failure - 3/23/2008 9:56:53 AM
mike early
Status: offline
I will try this stuff:
< Message edited by mike early -- 3/23/2008 9:57:08 AM >
