RE: Official E-FIRESTORM thread    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric Off-Road Trucks, Buggies, Truggies and more >> RE: Official E-FIRESTORM thread
Page: <<   < prev  7 8 [9] 10 11 12 13 14 15 16   next >   >>
Login
RE: Official E-FIRESTORM thread - 5/15/2008 8:21 PM
DARKWAV
Score: 110
Last Login: 3/7/2013
Status: offline
You can get by with the stock servo. I've been for some time now but am definately wanting something with more torque. I think it needs more holding power as a bumpy track feels as though it knocks the steering around a bit. Plus I notice the stock servo doesn't have enought power to help my truck get off the pipes when I get hung up. I feel like the steering servo should really be able to push the truck around more. I don't feel like I need to spend a ton of money on a servo though...at my rookie level of experience I don't feel like I need more speed, so I'm thinking the metal gear Hitec HS-645MG or Futaba S3305 at $32.00-$33.00 should be quite reasonable.
_____________________________
Savage Flux 2200Kv | E-Savage Trophy Truck 3100Kv | EX-1 Buggy 2200Kv | E-Firestorm Baja Bug 5700Kv | GB-01 Buggy 5400Kv
Hide Signatures
(in reply to dafpnp)
       Post #: 201
RE: Official E-FIRESTORM thread - 5/15/2008 8:22 PM
Oregon mud
Score: 100
Last Login: 3/16/2010
Status: offline
Im running a high torque/speed servo and it does help the truck handle cornering much better.
Hide Signatures
       Post #: 202
RE: Official E-FIRESTORM thread - 5/15/2008 8:26 PM
dafpnp
Score: 100
Last Login: 12/12/2010
Status: offline
There you go ... I am learning
Hide Signatures
(in reply to Oregon mud)
       Post #: 203
RE: Official E-FIRESTORM thread - 5/17/2008 5:36 PM
dafpnp
Score: 100
Status: offline
Has any one tried to increase the wheel base as its a feature claimed by HPI.
Well I did .. and its totally changed the way the truck handles.
Coming out of turns, the truck is much faster and lesser spin outs.
The truck would now hesitate to wheely though.
Here is how I did it.
Had to remove virtually everything from the rear of it except the shock towers.
Images continued in next message...
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by dafpnp -- 5/17/2008 5:51 PM >
Hide Signatures
       Post #: 204
RE: Official E-FIRESTORM thread - 5/17/2008 5:53 PM
dafpnp
Score: 100
Status: offline
Images continued ...
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 205
RE: Official E-FIRESTORM thread - 5/17/2008 6:02 PM
dafpnp
Score: 100
Status: offline
And my ESC would come loose very often .. infact every other impact would result in ESC hanging out or heat sink popping off.
Here is what I did ...
Base of ESC is now velcro instead of double sided tape. This absorbs most of the shock of an impact.
Not to take any more chances of loosing the heat sink , stuck some velcro in battery compartment and side of chasis to form a strap, further holding down the ESC.
Peace of mind ...
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 206
RE: Official E-FIRESTORM thread - 5/17/2008 7:26 PM
Oregon mud
Score: 100
Status: offline
I was wondering if you could change the arms like that. Looks like I will be taking mine apart again today. I Its first big race is tomorrow and I want it to haul ass!
Hide Signatures
       Post #: 207
RE: Official E-FIRESTORM thread - 5/17/2008 9:24 PM
73
Score: 100
Last Login: 12/15/2012
Status: offline
I've did that rear arms switching before, but seems like the joints may not be made for such a mod.
In stock form, the front end of the arm joint fits into the truck with a rounded tip, while the rear has a flat surface. Turning the arms around does increase wheelbase, and they do fit OK, but I switch back to stock since I'm not good enough to know the difference in handling, and after noticing the difference in the rounded & flat surfaces.
Hide Signatures
       Post #: 208
RE: Official E-FIRESTORM thread - 5/17/2008 10:00 PM
Oregon mud
Score: 100
Status: offline
I just turned mine around and I noticed the little nipple you are talking about. The worst that would happen is the tip of the nipple would rear off and cause a little slop in the rear arm that can easily be fixed with a small spacer. Im going to run it like this and see what it feels like. The arms and tires now sit in the center of the wells on the stock body now too so it looks nicer as well as longer.
Thank you dafpnp! I had never heard about this mod but Im glad you told me about it. PROPS!
Hide Signatures
(in reply to 73)
       Post #: 209
RE: Official E-FIRESTORM thread - 5/18/2008 12:29 AM
DriftingDragon
Score: 100
Last Login: 4/28/2013
Status: offline
dafpnp does the extended wheelbase help at all with stability
| AXIAL SCX10| Slash MAMBA MONSTER |DF-03 |
Hide Signatures
       Post #: 210
RE: Official E-FIRESTORM thread - 5/18/2008 1:38 AM
supamagician
Score: 100
Last Login: 6/21/2010
Status: offline
heyy guys. i just hit my e-firestorm into a curb at about 20 mph and now, it wont run. i checked all connections and they are fine but you know how when you turn one wheel, the other spins, but the opposite direction? well it does that but when i just roll it on the ground, neither of the back wheels will roll. help please?
thanks,
rob
Hide Signatures
(in reply to DriftingDragon)
       Post #: 211
RE: Official E-FIRESTORM thread - 5/18/2008 2:05 AM
Oregon mud
Score: 100
Status: offline
Did the motor shift forward and cram the pinion gear into the spur gear? Thats what it sounds like to me.
Hide Signatures
(in reply to supamagician)
       Post #: 212
RE: Official E-FIRESTORM thread - 5/18/2008 2:14 AM
DriftingDragon
Score: 100
Status: offline
disassemble the whole rear end and rebuild and see if that helps
Hide Signatures
       Post #: 213
RE: Official E-FIRESTORM thread - 5/18/2008 2:25 AM
ELK
Score: 100
Last Login: 4/26/2012
Status: offline
sounds like the diff went
Hide Signatures
       Post #: 214
RE: Official E-FIRESTORM thread - 5/18/2008 2:27 AM
Oregon mud
Score: 100
Status: offline
Well, that aught to keep him busy for a little while.
Hide Signatures
(in reply to ELK)
       Post #: 215
RE: Official E-FIRESTORM thread - 5/18/2008 3:13 AM
DriftingDragon
Score: 100
Status: offline
still safe to check everything anyways
Hide Signatures
       Post #: 216
RE: Official E-FIRESTORM thread - 5/18/2008 4:18 AM
Oregon mud
Score: 100
Status: offline
Oh I totally agree. I tear my truck down when it is working just fine. I have had my Firestorm apart more times than I have ran it. I find little problems and fix them before they can cause me any unscheduled down time.
Hide Signatures
       Post #: 217
RE: Official E-FIRESTORM thread - 5/18/2008 4:36 AM
DARKWAV
Score: 110
Status: offline
quote:
ORIGINAL: Oregon mud
That's what I'm thinking too. Diff is probably fine, seems like the bevel gears inside it are working properly. Also I can't imagine anything shifting around inside the transmission.
Hide Signatures
       Post #: 218
RE: Official E-FIRESTORM thread - 5/18/2008 5:39 AM
dafpnp
Score: 100
Status: offline
quote:
ORIGINAL: DriftingDragon
Stability was never an issue... but I feel its better in a way that from turns, egress is faster. However, for ingress, using drag brakes just before turning gives better steering response.
Hide Signatures
       Post #: 219
RE: Official E-FIRESTORM thread - 5/18/2008 5:51 AM
supamagician
Score: 100
Status: offline
what is a diff? also, im at my dads so i dont have my tools but ill try to find some hex keys to check it out
Hide Signatures
       Post #: 220
RE: Official E-FIRESTORM thread - 5/18/2008 6:31 AM
supamagician
Score: 100
Status: offline
well guys, who ever said that the pinion gear could be rammed into the spur gear, i cant thank you enough!! thats exactly what it was. i fixed it and its running ok now. does anyone else have a tazer 15t esc in there e-firestorm and run a 5000 nimh or higher batt.? i run that esc and that batt. and i have fried the connector of the esc. on one side of the connector, the plastic is melted. and i dont think im getting all the power i should be. what can i do to fix this problem?
Hide Signatures
       Post #: 221
RE: Official E-FIRESTORM thread - 5/18/2008 6:46 AM
Oregon mud
Score: 100
Status: offline
I was running the tazer and a 5000 mah battery and mine started melting too, not in my Firestorm, but thats irrelevant. I ended up having to switch over to the deans ultra plugs and havent had a problem since. I use them for the battery and the motor to ESC connections.
Hide Signatures
       Post #: 222
RE: Official E-FIRESTORM thread - 5/18/2008 7:48 PM
73
Score: 100
Status: offline
Yeah, the Deans connectors worked flawlessly. I had them on all my batteries even before starting out, some experience buddies suggested I switch thosr bullet plugs and it was good advice.
The only problem occurs with deans is when too much dirt gets onto the connections, there's probably some inteference which causes carbon built up. When that happens the deans connectors gets hot during & after runs, which will be time to scrap & clean those connections.
* Correct me if I'm wrong. I'm new.
Hide Signatures
       Post #: 223
RE: Official E-FIRESTORM thread - 5/18/2008 11:01 PM
DriftingDragon
Score: 100
Status: offline
go trx better terminal coverage but same current if not better
Hide Signatures
(in reply to 73)
       Post #: 224
RE: Official E-FIRESTORM thread - 5/18/2008 11:47 PM
supamagician
Score: 100
Status: offline
yeah my firestorm is KILLED. it will not run worth poop because the wires are fried. i guess im gunna have to add however much the deans cost to the $160 i already owe my stepdad lol. how much will it cost me to get the deans plugs?
Hide Signatures
       Post #: 225
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.578RCU1
