RE: Official E-FIRESTORM thread
Tower Hobbies
Logged in as Guest
  Printable Version
HIMOTO Mamba or Eldorada 12MM HEX Wheel Extensions
Seller:  wheelextensions
Details:   $20.00   |  8/24/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric Off-Road Trucks, Buggies, Truggies and more >> RE: Official E-FIRESTORM thread
Page: <<   < prev  1 [2] 3 4 5 6 7 8 9 10   next >   >>
Login
RE: Official E-FIRESTORM thread - 3/26/2008 7:12:58 PM
Redvanmafia
Status: offline
well you have the top big guys, Losi and Ae, they make a nice st, for racing and such, then you have your more starter st's like Evaders Rustlers that type thing so the markets full its covered from Expert to Beginner, will HPI be able to make a stab and take or have a spot with these St's/trucks that have been around for a while? Look at the raven and that, people thought it was gonna be great but..... i donno, ware does the firestorm stand in most peoples eyes?, is it a racing cablable rig like a losi or ae or is it more in the beginner ST crowd?
< Message edited by Redvanmafia -- 3/26/2008 7:14:34 PM >
_____________________________
:Brushless trucks:
Stampede & Mini-t
(in reply to Enzyme80)
       Post #: 26
RE: Official E-FIRESTORM thread - 3/26/2008 9:15:37 PM
green_overcomer
Status: offline
Hi guys. It has been advertised that the E-Firestorm is brushless ready. I have the red one with everything stock. I would like to shift to brushless soon, but I'd like to assume that I don't need to replace my batteries, ESC and gear combinations anymore as it is considered "brushless" ready. Am I correct in my assumption? If otherwise, can someone recommend good but affordable brands for the brushless motor, ESC, etc. Many thanks!
(in reply to Redvanmafia)
       Post #: 27
RE: Official E-FIRESTORM thread - 3/26/2008 9:22:14 PM
rbjeepthing
Status: offline
quote:
ORIGINAL: Redvanmafia
You missed the most common area. HPI has filled the void between a cheap inexpensive entry level truck and a top of the line set-up. The E-Firestorm falls right in the middle and has the price of the less expensive trucks and the quality parts of the more expensive trucks where they are needed. Effectively bridging the gap between the two.
I have had mine out about 30 times now and have bashed it pretty good including landing upside down off a second story. I have only broke 2 ball studs. I have been running with guys who have Losi, AE and Traxxas vehicles and I can tell you mine has had far less down time then any of their trucks. The only difference I have found when sport racing is the AE had better handling out of the box. However I through some AE shocks on mine and set-up and now feel it handles just as well.
I purchased one of the first E-firestorms from my lhs then they didn't sell much of them cause people were skeptical like yourself. Last week 4 guys were watching us race and after seeing my truck perform against the AE and Losi trucks 3 of them bought the E-Firestorm. I asked them why the decided to get it and they said simply "Best bang for the buck". I would agree.
       Post #: 28
RE: Official E-FIRESTORM thread - 3/26/2008 10:38:03 PM
Enzyme80
Status: offline
quote:
ORIGINAL: green_overcomer
I am pretty sure you have to replace the ESC. The one it comes with is rated for 15 turn brushed motors and above. Someone can correct me if I am wrong but that is my understanding.
E-firestorm with SW 4600 otherwise stock.
(in reply to green_overcomer)
       Post #: 29
RE: Official E-FIRESTORM thread - 3/27/2008 12:20:19 AM
DARKWAV
Status: offline
You need to replace the stock ESC and motor with a brushless ESC and motor. Your batteries will need high current connectors that you will need to solder on such as Deans connectors or Traxxas high current connectors.
The best deal out there right now is the Sidewinder 5700 system (brushless ESC and motor combination) for about $130-150 depending on where you buy them and what discounts are available at the time. 5700 is good because it is fast on 6 cells.
For batteries you should at least be running 3000 mAh 6 cell stick packs...even Venoms work. Of course you'll get even greater performance out of better batteries.
Stock gearing works fine on an E-Firestorm with Sidewinder 5700.
My friend has a red E-Firestorm also. Completely stock except for the Sidewinder 5700 system. He used Deans plugs for the batteries and ESC. Just to be on the safe side we swapped out the connectors on his Castle motor (there can be some reliability issues with the original connectors ... which may be more noticable when running lower quality batteries like Venom 3000/3600 batteries) for 4 mm CC Bullets.
I've also got the Sidewinder 5700 in my E-Firestorm.
"Brushless Ready" is more or less referring to the fact that HPI incorporated an all-metal transmission and sealed gear differential that can reliabily withstand the stresses of brushless power.
< Message edited by DARKWAV -- 3/27/2008 12:25:34 AM >
HPI E-Firestorm 10T / HPI E-Savage / Tamiya TamTech-Gear GB-01
       Post #: 30
RE: Official E-FIRESTORM thread - 3/27/2008 10:49:38 AM
green_overcomer
Status: offline
Thank you DARKWAV for the comprehensive response. I'll see if I can order some from Towerhobbies soon.
(in reply to DARKWAV)
       Post #: 31
RE: Official E-FIRESTORM thread - 3/27/2008 3:09:47 PM
Access
Status: offline
Most people aren't racing at the pro level, they are racing at the club level where even a rustler can get 3rd or 4th place (in a race of 6) if it is set up and driven well. The E-firestorm might not make all the sacrifices that a T4 or XXX-T makes as far as weight, but it is 80% of the way there and club level racing just isn't that competitive to the point where it will make a noticeable difference.
       Post #: 32
RE: Official E-FIRESTORM thread - 3/27/2008 3:53:53 PM
Eman77
Status: offline
Spiffy shocks just dying to be on the E-Firestorm...
*drool*
Click to see fullsize image.
Click for fullsize
Schumacher Bosscat, Tamiya DT02-MS, HPI E-Savage, Tamiya DB01 Durga
(in reply to Access)
       Post #: 33
RE: Official E-FIRESTORM thread - 3/27/2008 4:29:42 PM
DARKWAV
Status: offline
Pictures of my E-Firestorm...
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 34
RE: Official E-FIRESTORM thread - 3/27/2008 4:35:07 PM
Eman77
Status: offline
Nice! Dig the shocks, man.
       Post #: 35
RE: Official E-FIRESTORM thread - 3/27/2008 7:26:57 PM
DARKWAV
Status: offline
More E-Firestorm pictures. In their natural habitat...
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to Eman77)
       Post #: 36
RE: Official E-FIRESTORM thread - 3/27/2008 7:34:44 PM
annie_himself
Status: offline
quote:
ORIGINAL: DARKWAV
Can you say "sex appeal?"
Saldly, 98% of teens have switched to rap music, if you're part of the other 2% that like real hip-hop put this in your sig.
       Post #: 37
RE: Official E-FIRESTORM thread - 3/28/2008 2:39:06 AM
rbjeepthing
Status: offline
Since this is now becoming a pic thread too I decided to jump in!
(in reply to annie_himself)
