Pouring Methanol
Tower Hobbies
Logged in as Guest
  Printable Version
XYZ-26cc Gas Engine
Seller:  XYZUSA
Details:   $219.00   |  4/26/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> Pouring Methanol
Page: [1]
Login
Pouring Methanol - 3/9/2002 9:51:04 AM
kylenlord
Status: offline
My father recently purchased a 5 gallon metal drum of pure Methanol to mix some Super Tigre fuel. It clearly states on the can to ground it so no sparks will occur. If it were just my father pouring the fuel then I wouldn't bother to ask, but since I will be helping, what is the method to grounding to can as to not cause any sparks?
Kyle Lord
       Post #: 1
Pouring Methanol - 3/9/2002 5:03:17 PM
Ed Smith
Status: online
Don't bother to ground it. Just get your Dad to pour it out!
Ed S
(in reply to kylenlord)
       Post #: 2
grounding during fueling - 3/9/2002 7:49:12 PM
springcreek
Status: offline
As an A&P mechanic I can tell you that grounding during fueling is not an issue to be brushed aside. Pouring fuel can create static electricity and if it builds up, it can produce a spark similar to touching a doorknob after dragging your feet across the carpet. Obviously, this is not a good thing when dealing with fuels. To be properly grounded, the fueling source must be grounded to the ground and to the fuel recepticle. (Fuel truck to ground and truck to airplane.) If you are pouring from a metal can into another metal can, use something similar to jumper cables between the two containers. If you are pouring into a plastic container, the possibility of a spark there is nil. It is also advisable to run a cable from the fuel can to a grounding pole, ie. a lightning rod on a house, or a copper rod driven into the ground.
In all honesty, I don't think you need to go to great lengths on this as you will most likely be dealing with minimal quantities of fuel. In most cases, it takes a great volume of moving fuel to create enough static charge to pose a danger. In the case of full scale aviation, the volume of fuel moving is significant enough to take the above precautions.
       Post #: 3
Pouring Methanol - 3/9/2002 8:14:42 PM
edge_fanatic
Status: offline
LOL......So, if your dad pours it, no grounding is necessary? ....possibly leading to you receiving any inheritance early?
I had to laugh....
       Post #: 4
Pouring Methanol - 3/9/2002 9:44:20 PM
Elwood
Status: offline
I would ground it. It says so on the can. Wire it to a copper water pipe.
Also, plastic can build up static electricity and cause a spark.
_____________________________
Born in the U.S.A.......Not quite as long ago as Art!!!!!!!
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.395RCU1
