New Saito 115 at Horizon
Tower Hobbies
Logged in as Guest
  Printable Version
90 Degree Muffler Adapter
Seller:  RC Specialties
Details:   $17.95   |  5/19/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> New Saito 115 at Horizon
Page: [1] 2   next >   >>
Login
New Saito 115 at Horizon - 3/22/2008 4:28:25 AM
w8ye
Status: offline
http://www.horizonhobby.com/Products/Default.aspx?ProdID=SAIE115
_____________________________
I've attended the CutFinger Institute of DirtNap University for years but never did graduate....
Club Saito Member #7
Original AMA #31261
       Post #: 1
RE: New Saito 115 at Horizon - 3/22/2008 5:02:59 AM
krayzc-RCU
Status: online
kewl
smooth as silk!
(in reply to w8ye)
       Post #: 2
RE: New Saito 115 at Horizon - 3/22/2008 5:41:25 AM
rcdude7
Status: offline
Looks much like the 1.00
(in reply to w8ye)
       Post #: 3
RE: New Saito 115 at Horizon - 3/22/2008 2:35:51 PM
Ken6PPC
Status: online
quote:
ORIGINAL: rcdude7
No, I don't think it looks like the 100. Take a look at the two pictures side by side. The 100 is on the left, and the 115 is on the right. The 115's cylinder looks to be a bit shorter than the 100, which means it has a shorter stroke. Since the overall displacement is larger on the 115, that also means it has a larger bore than the 100.
If (and I do mean IF) this is true, it should mean the two engines would perform differently. The lower height would also mean that the 115 will fit entirely inside the cowl of some planes, where the 100 would have to stick out of the same cowl.
In MY opinion, the more Saito models we have, the better off we are! Besides, it is another reason to buy a new engine!
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by Ken6PPC -- 3/22/2008 2:49:42 PM >
Club Saito Member #370
AMA #853194
(in reply to rcdude7)
       Post #: 4
RE: New Saito 115 at Horizon - 3/22/2008 3:48:56 PM
Hobbsy
Status: offline
I just called one of my Buds, Stanley, who works at Apex Hobbies on Saturdays, he has a brand new Horizon Catalogue but no mention of the 1.15. So, to quote Ace Ventura, "I'll just wait longer".
Giant Saito, 73.2 Cu. In., 70.5HP @ 5,800 rpm, 79 ft. lbs torque @ 3,500 rpm, 57 mpg, 3.50 bore, 3.81 stroke. 563 lbs.
(in reply to Ken6PPC)
       Post #: 5
RE: New Saito 115 at Horizon - 3/22/2008 8:05:07 PM
w8ye
Status: offline
The 115 uses the piston/valves from the 125 and the carb from the 100.
Following the recent trends by the manufactures of bigger valves and shorter stroke for the displacement/
Original AMA #31261
(in reply to Hobbsy)
       Post #: 6
RE: New Saito 115 at Horizon - 3/24/2008 3:01:01 PM
jvino
Status: offline
Any news on release date??
(in reply to w8ye)
       Post #: 7
RE: New Saito 115 at Horizon - 3/24/2008 6:27:49 PM
w8ye
Status: offline
Horizon will ship them to dealers and you will most likely see them in the LHS showcase before they actually announce in stock availability over the internet.
Original AMA #31261
(in reply to jvino)
       Post #: 8
RE: New Saito 115 at Horizon - 3/28/2008 11:10:10 PM
Pete Bergstrom
Status: offline
This engine does combine the piston/cylinder from the FA-125 with a crancase based on the 91. It has the same width as the 91 (3mm smaller than the 100) but has the improved and stronger cam housing and crankcase. We expect these late May or early June.
Pete
Saito Product Manager
Horizon Hobby
       Post #: 9
RE: New Saito 115 at Horizon - 3/29/2008 10:36:36 PM
jvino
Status: offline
How about some specs Pete?? Weight would be on top of that list but whatever you have available would be very helpful.
(in reply to Pete Bergstrom)
       Post #: 10
RE: New Saito 115 at Horizon - 3/30/2008 12:56:16 AM
rustypep
Status: offline
I am curious about the weight and height. It might be a good option for a 60 Spit if it is shorter than the 1.00.
quote:
ORIGINAL: jvino
Club Saito Member 354
(in reply to jvino)
       Post #: 11
RE: New Saito 115 at Horizon - 3/30/2008 8:42:58 AM
N1EDM
Status: online
I wonder what the performance differences are between that and the .125. They are pretty close in displacement, so there would have to be some additional kind of incentive to manufacture and produce two engines with displacements this close together.
I could see them trying to upgrade the 100, but I wonder if this will also take the place of the 125? Isn't the 125 a fairly new release in the past couple of years? Seems kind of odd that they would sink all that R&D and tooling money into two engines that could be close together performance-wise.
Just tossing this out...
Bob
An expert is someone who has been doing it for 15 minutes longer than you.
(in reply to rustypep)
       Post #: 12
RE: New Saito 115 at Horizon - 3/30/2008 12:41:46 PM
FlyingPilgrim
Status: offline
I'm with you, Bob. Still scratching my head as to why. Normally I believe the more choices the better, but I am wondering what the benefit of this one is. Time will tell once users have the chance to do side-by-side comparisons. I am also curious about the "improved and stronger cam housing design", as I don't recall anyone having failures in that area. Just my opinion, but I still think the older design of the rounded cam housing looks better (like the .91 etc.). It must allow lighter weight with strength compared to the old design crankcase.
I know just enough to be dangerous
(in reply to N1EDM)
       Post #: 13
RE: New Saito 115 at Horizon - 3/30/2008 1:56:46 PM
w8ye
Status: offline
I've been waiting for the new "92" that has a 125 bore with a 82 crank and smaller crankcase.
Original AMA #31261
(in reply to FlyingPilgrim)
       Post #: 14
RE: New Saito 115 at Horizon - 3/30/2008 2:27:45 PM
N1EDM
Status: online
I think that Ken6PPC might have said it best. Shorter stroke = different performance.. I wonder if the 115 will be optomized for smaller low-pitch props props turning fast, and the 125 for larger high-pitch props turning slower...
Just a thought.
       Post #: 15
RE: New Saito 115 at Horizon - 3/30/2008 3:39:52 PM
AA5BY
Status: offline
Could fuel consumption be at play? The 125 is pretty fuel hungry and at least as far as I'm concerned is getting competition from gassers like the Zenoah G-20 that are encroaching into the top end of the glow zone. I own a Saito 125 and two G-20s. Power is about the same but cost of operation of the G-20 is far less at 5-6 oz of gas per flight compared to 18-22 oz of expensive glow fuel. The G-20 is such a sweet motor and is now selling cheaper than the Saito, is much cheaper to operate, easier to start, and easier to clean up after.
Could the 110 be an attempt at getting back to the Saito reputation for good fuel economy? I've a Saito 30, 50, 56, 90 twin and the 125 and only the 125 seems thirsty.
(in reply to N1EDM)
       Post #: 16
RE: New Saito 115 at Horizon - 3/30/2008 4:05:00 PM
octanehuffer
Status: offline
Regardless of the point, it is good that there more optins for Satio's. The small blocks have always been .10ci apart. The .56, .62, .72, .82, .91, 1.00, 1.15, 1.25
I might try the 1.15 in a Funtana 90
QQ 86" Evolution, QQ 69" Saito 1.25, QQ 49" 32SX, QQ E-Yak, Funtana 90 Saito 1.20, H9 T-Craft G-26, etc
(in reply to AA5BY)
