No Antenna for Buddy Box?
Tower Hobbies
Logged in as Guest
  Printable Version
JR NES703 Low Profile Retract Servo
Seller:  Erick Royer
Details:   $75.00   |  9/2/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> JR Radio & Spektrum Radios Support Forum >> No Antenna for Buddy Box?
Page: [1]
Login
No Antenna for Buddy Box? - 3/22/2008 7:35:03 PM
propbuster
Status: offline
I have a couple of XF421ex transmitters and want to use one as a buddy box. I can't for the life of me find the antenna for one of them. Will I damage the one I use for a buddy box by not having the antenna installed on it? Does the transmitter need some kind of load on the output so as not to harm it? Thanks!
_____________________________
Never run out of Altitude, Airspeed or Ideas all at the same time.
http://blueridgeaeroworks.blogspot.com/
       Post #: 1
RE: No Antenna for Buddy Box? - 3/22/2008 11:24:23 PM
onewasp
Status: offline
NO!
The buddy box is always "OFF", only the master is on. Try it the other way and 'adios'.
The ground reached up and smote my airplane
(in reply to propbuster)
       Post #: 2
RE: No Antenna for Buddy Box? - 3/23/2008 12:09:42 AM
propbuster
Status: offline
Well, not really, as as soon as you plug in the cord to the buddy box it turns on!
(in reply to onewasp)
       Post #: 3
RE: No Antenna for Buddy Box? - 3/23/2008 2:21:09 AM
onewasp
Status: offline
Again, unless you have something VERY unusual it does NOT turn on.
It will operate the master so its pots are active so long as the master trainer switch is activated. If the master trainer switch is released the Buddy Box does zip-----so it is not in any way on!
Are you REAL:LY having difficulty in understanding on and off or is this a 'put on'??
       Post #: 4
RE: No Antenna for Buddy Box? - 3/23/2008 4:40:36 AM
bob1393
Status: offline
onewasp - propbuster is correct - slave Tx does indeed turn on when you plug in the buudy box cord to it. I've flown buddy boxes several times, and the salve Tx does turn on - at least the screen lights up. I do think it is not necessary to have the antenna in as the slave Tx is not generating any RF.
Bob
       Post #: 5
RE: No Antenna for Buddy Box? - 3/23/2008 12:16:51 PM
propbuster
Status: offline
onewasp, what are you a wise guy? I certainly know the difference between ON and Off and how a buddy box arrangement works. My question that bob1393 understood, was regarding damaging the output circuit of the TX as I know that while it's not going to be transmitting any RF signal, most output circuits need at least a Dummy load on them. Seeing as the JR system is different than say a Futaba which doesn't even need a battery, and the JR needs a battery and seems to turn on with the cord attached, there arose my concern regarding not having the antenna with it. bob1393, thanks for your input!
(in reply to bob1393)
       Post #: 6
RE: No Antenna for Buddy Box? - 3/25/2008 12:49:55 AM
codimasta
Status: offline
The buddy box doesnot emit a RF Signal...when you plug in the trainer cord....it activates the encoder only...the Buddy Box transmitter switch is in the OFF position.
The same thing happens when you plug in the DSC cord into the transmitter and the other end into the charge plug..(be sure you are using a JR 3 line switch),
you can setup your model without turning the Transmitter on..
I do hope that this will help...
Codimasta
AMA 11269
       Post #: 7
RE: No Antenna for Buddy Box? - 3/25/2008 1:14:50 AM
propbuster
Status: offline
Thanks for clearing this up for me! Prop
(in reply to codimasta)
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.922RCU1
