Senior Telemaster suggestions
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Kit Building >> Senior Telemaster suggestions
Page: [1]
Login
Senior Telemaster suggestions - 3/22/2008 10:05:03 PM
tennessee_flash
Status: offline
A friend of mine gave me his Senior Telemaster 9 years ago. The airplane had been sitting for about 20 years or more. He flew the airplane 3 or 4 times and then had the Telemaster blow out of the back of his truck on the way to the field. I took the old covering off and rebuilt the airframe. The airframe looks good with no warps. I covered the airplane in yellow Super Coverite to look like a Cub. I installed a MVVS .61 engine and JR radio equipment. I noticed on the first takeoff that the rudder is inadequate with a crosswind so I took off on the grass runway. After takeoff the airplane didn't want to turn so I yelled "HEADS UP" because the airplane was headed for the flight line. I used the rudder to get the airplane back on the ground. After inspecting the airplane and determining the ailerons were working, I took off again. Again I had the same problem. I can move the ailerons full travel and the airplane won't roll. I'm using an aileron servo in each wing. The airplane also isn't stable in the roll axis(doesn't want to trim out). Because I don't have a manual I just eyeballed the amount of aileron travel. I'm not using any aileron differential which could be part of the problem on a flat bottom wing. The only mod to the kit besides 2 aileron servos is the wing bolts for mounting the wing. I'm looking for suggestions because my smaller Telemaster flies great except for lack of rudder control(too small of rudder area).
TF
       Post #: 1
RE: Senior Telemaster suggestions - 3/22/2008 11:15:29 PM
MinnFlyer
Status: offline
Try increasing the throw. Differential won't do anything noticable.
Also seal the aileron gaps.
_____________________________
Mike B.
AMA# 42400 www.gettingairborne.com
"Those are my principles. If you don't like them, I have others." - Groucho Marx
(in reply to tennessee_flash)
       Post #: 2
RE: Senior Telemaster suggestions - 3/22/2008 11:36:49 PM
tschuy
Status: offline
I've had the same experience with mine and found that adding an additional 2" to the rudder cured the lack of Yaw control. Also it sounds like you may not have enough of a percentage on your aileron surface. Old school rules were typically you wanted between 7 to 10 percent of your total wing surface to be aileron on the slower moving sport type models to have enough affective surface to roll the airplane around. Least that's what I can remember from the Clarence Lee articles posted in the RCModelor magazine.
Cheers,
Tim Schuy
tschuy@comcast.net
(in reply to MinnFlyer)
       Post #: 3
RE: Senior Telemaster suggestions - 3/23/2008 1:44:45 AM
tennessee_flash
Status: offline
Thank you Mike and Tim. My friend used some of the original aileron material for short pieces of flap. He might have cut down the aileron area too much. I'll seal the hinges and increase the throw to start with. The rudder area looked too small to start with but it was already hinged and tapered so I haven't increased the area of the rudder yet.
TF
(in reply to tschuy)
       Post #: 4
RE: Senior Telemaster suggestions - 3/23/2008 3:29:40 AM
Ed Cregger
Status: online
quote:
ORIGINAL: tennessee_flash
TF
Models such as the Telemaster and Sig Kadet and Mk.II have been known to have adverse yaw cancel out the roll of the ailerons. A friend of mine's Kadet (original kit) would not turn with aileron and elevator inputs for just this reason. We had to drill new holes in the servo output wheel that made the high aileron go much further up, then it did down in the opposite turning direction. In other worlds full right aileron would provide large amounts of upward deflected aileron on the right wing with not as much throw downward on the left aileron. That straightened out his problem of not being able to roll into a turn using just aileron and then compensating with elevator in order to maintain altitude. I hope that was understandable.
I agree with the other posters that the Telemaster series models have skimpy control surfaces to begin with.
Ed Cregger
Artisan
"Flying models since the Fifties - I'll get the hang of this yet!!!"
       Post #: 5
RE: Senior Telemaster suggestions - 3/23/2008 4:41:27 AM
rryman
Status: offline
Well, I'm glad I'm not the only one that's had a Senior Telemaster blow out of the back of a truck!! Had the same thing happen to me once. Thankfully, it was minimal damage. I also added to the rudder on both the .40 size and Senior Telemaster for better performance. Now I have the rudder coupled with the ailerons on both my Senior and Giant Tele. Getting lazy I guess!
Randy
(in reply to Ed Cregger)
       Post #: 6
RE: Senior Telemaster suggestions - 3/23/2008 9:18:18 AM
Ed Cregger
Status: online
quote:
ORIGINAL: rryman
Randy
Which engine is powering your Giant Telemaster? I bought the kit a short while back and have been thinking of powering it with a G-62, but that might be too much. Any thoughts?
A good friend of mine had his Telemaster 40 blow out of the back of his pickup too. My pickup had a cap, saving me that kind of problem. Now I'm driving a minivan. Frankly, I miss the little Ford Ranger pickup, even though it didn't have room for large models, without turning the models into smaller pieces.
Ed Cregger
Artisan
(in reply to rryman)
       Post #: 7
RE: Senior Telemaster suggestions - 3/23/2008 1:09:25 PM
rryman
Status: offline
I've got a G45 on mine, and it comes out pretty nose heavy with that. Another guy here is putting one together with a G62, but hasn't flown it yet. I think you'll probably have to add a good bit on tail weight, but should still fly OK. Mine topped out at 23#. If you like the other Telemasters, you'll love this one. I had a build thread on it some time back.
Randy
       Post #: 8
RE: Senior Telemaster suggestions - 3/23/2008 5:33:06 PM
Gray Beard
Status: offline
I used the OS .60 on mine and it was about perfect for the plane. I just flew it, I didn't use it as A tow or anything. A G-62 could be A lot of fun.
Mine didn't have any aileron control problems and I cut the ailerons down by A third for flaps. It did need some rudder input on turns though just to give it some help and I had A lot of throw on the ailerons.
One of the planes I had the most fun with. Got to fly another one two weeks ago and loved it, could have had some more wind though, that's when they start getting with the program.
If drinking and driving are illegal, then why do bars have parking lots???
       Post #: 9
RE: Senior Telemaster suggestions - 4/18/2008 2:57:59 PM
ERJ_Pilot
Status: offline
quote:
ORIGINAL: Gray Beard
I was thinking of building one and using an OS 60 that I have. Do you think you could tow a 2M sailplane with that?
(in reply to Gray Beard)
       Post #: 10
RE: Senior Telemaster suggestions - 4/18/2008 4:07:56 PM
jaka
Status: offline
Hi!
The senior Telemaster flies fine on a old .60 OS four stroke (the first model of that engine swinging a 14x4 prop).
With a two stroke .61 engine swinging the same prop or a 13x5-13x6 APC you should be able to tow a 2m sailplane just fine.
Jan Karlsson Airracing products
MVVS, Motul "Micro" all synthetic oil
(in reply to ERJ_Pilot)
       Post #: 11
RE: Senior Telemaster suggestions - 4/18/2008 6:25:49 PM
Ed Cregger
Status: online
quote:
ORIGINAL: rryman
I've got a G45 on mine, and it comes out pretty nose heavy with that. Another guy here is putting one together with a G62, but hasn't flown it yet. I think you'll probably have to add a good bit on tail weight, but should still fly OK. Mine topped out at 23. If you like the other Telemasters, you'll love this one. I had a build thread on it some time back.
Randy
The G62 I would use has been modified by Ralph Cunningham. It is one of his G62 Lite engines with EI, which should be considerably lighter than your G45 (used to own one of those too, nice engine).
Ed Cregger
Artisan
       Post #: 12
RE: Senior Telemaster suggestions - 4/18/2008 6:29:34 PM
Ed Cregger
Status: online
We skipped a groove on you, Gray Beard, and began talking about the Giant Telemaster (12' Telemaster).
The Senior Telemaster will fly just fine with a .60 sized glow engine, as you have already noted.
I like to have an excess of control authority. It permits me to fly these lightly loaded models on windy days without worrying about not having enough control authority to pull the model out of awkward situations.
Ed Cregger
Artisan
       Post #: 13
RE: Senior Telemaster suggestions - 4/18/2008 8:22:08 PM
jbarnes
Status: offline
I fly my giant and senior with differential aerlions and couple 20% rudder and they both fly much better. And my Giant has a G62 Ed.
President Longmont Aircraft Modelers Association
Longmont, CO visit our site at www.lamarcclub.com
       Post #: 14
RE: Senior Telemaster suggestions - 4/18/2008 8:49:29 PM
Ed Cregger
Status: online
Yep, you just about have to coordinate the turns (rudder and aileron applied simultaneously) on models such as the Telemaster, in virtually any size.
How do you feel about the G62 in your 12' Tele? Too much? Over the top? Just right?
Ed Cregger
Artisan
(in reply to jbarnes)
       Post #: 15
RE: Senior Telemaster suggestions - 4/18/2008 9:27:09 PM
jbarnes
