RE: Going Slow is The Way To Go - Tamiya CR-01 Resource Thread!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric Off-Road Trucks, Buggies, Truggies and more >> RE: Going Slow is The Way To Go - Tamiya CR-01 Resource Thread!
Page: <<   < prev  2 3 [4] 5 6 7 8 9 10 11   next >   >>
Login
RE: Going Slow is The Way To Go - Tamiya CR-01 Resou... - 4/24/2008 9:59:39 AM
Zeffle
Status: offline
Apparently the stabilizer set is plastic as well
quote:
Check page 1, post #3!!
I thought i read through this thread!!
thanks LB your a legend[)]
< Message edited by Zeffle -- 4/24/2008 10:00:28 AM >
_____________________________
DF02, brushless - TLT-1, in bits - CR-01, modded
(in reply to cornel4web)
       Post #: 76
RE: Going Slow is The Way To Go - Tamiya CR-01 Reso... - 4/24/2008 2:44:50 PM
Lunchboxer
Status: offline
I am pretty sure the stabilizer will be made of steel... it is a torsion bar setup.. !! Silly rcMart!
LB | WW2 | TLT | TB02 | DF03 | TEgg | TC4FT | F103GT | TXT | Hornet | M03M | Frog | Scalpel | Leo 2A6 | Aeromax | WW1 | Clod
(in reply to Zeffle)
       Post #: 77
RE: Going Slow is The Way To Go - Tamiya CR-01 Reso... - 4/24/2008 3:01:38 PM
tjscrogins99
Status: offline
You guys should try running a good 35t motor. Like this one, http://www.jpcustomrcs.atomicshops.com/catalog/item/4859786/5254837.htm
I run one in my crawlers, they are sweet, allow you to go veeerry slow and have some wheelspeed as well. I run a 3 cell lipo 2100mah with it and get 2 hours of runtime.
(in reply to Lunchboxer)
       Post #: 78
RE: Going Slow is The Way To Go - Tamiya CR-01 Reso... - 4/24/2008 3:12:39 PM
Lunchboxer
Status: offline
Just curious why do you go higher turn on the motor and then up the voltage.. I mean, I understand that this allow you to generate more power.. but is that much power really needed?
I mean, why not a 27T motor w/ 7.2V, for example... if you want to go slow, why use the 3S li-po?
Just curious.. thanks!!
(in reply to tjscrogins99)
       Post #: 79
RE: Going Slow is The Way To Go - Tamiya CR-01 Reso... - 4/24/2008 9:25:32 PM
tjscrogins99
Status: offline
When I have tried using a 27t for example, it did not have the low end tourque and super slow speed needed for crawling, but it had decent wheelspeed. The motor would stall if bound just a little. Of course quality of motor has alot to do with it as well but I could not get the slow speed control at all. And a 35-45-55 lathe motor on 7.2 has great slow speed control and OK wheelspeed, but bump it up to 3 cell and you get all the slow speed with enough top end to jump up and over some rocks if you need to. Or throw some dirt around. Plus the lipo batteries I use are half the size/weight and still last 2 hours. I run 15c or 20c 2100mah 3 cells I bought for under 50 bucks and they dont even get warm after 2 hours.
www.holmeshobbies.com has some really cool 7t puller motors that can go very slow and very fast off of a 7.2v pack but they cost 79.99. check em out.
       Post #: 80
RE: Going Slow is The Way To Go - Tamiya CR-01 Reso... - 4/24/2008 9:30:20 PM
Lunchboxer
Status: offline
Cool.. that makes sense.. I think I will give the stock silvercan a try first, though.. then see if I should spend more money on changing that out!
Have you ever tried the bigger can motor? Such as the 550-sized motor for the extra torque?
       Post #: 81
RE: Going Slow is The Way To Go - Tamiya CR-01 Reso... - 4/25/2008 1:42:44 PM
tjscrogins99
Status: offline
I have tried big powerful 1000kv brushless motors, able to snap the drivline if you arnt careful, but they dont have the slow speed control like a brushed.
Try the silver can, theres a guy who run only those at our comps, does fine, has ok slow speed and enough stop end to smoke the tires. With the gearing reduction listed for the cr 01 it may handle it just fine. There are people who use a good 19t and make a rock racer as well.
Ive already been spoiled by the 35t warrior and 3 cell, i dont think i can ever go back. Just ordered another one actually.
Post up on here how you like the stock can.
       Post #: 82
RE: Going Slow is The Way To Go - Tamiya CR-01 Reso... - 4/25/2008 1:44:07 PM
tjscrogins99
Status: offline
Oh, to answer your question, no never tried a 550. Give it a shot, as long as its brushed and has the tourque for low rpm without binding you should be able to go as slow as you want.
       Post #: 83
RE: Going Slow is The Way To Go - Tamiya CR-01 Reso... - 4/25/2008 2:31:14 PM
Lunchboxer
Status: offline
Yeah, I might stick a S600 in it! I have that w/ my TLT and thought that's a pretty good setup... !!
       Post #: 84
RE: Going Slow is The Way To Go - Tamiya CR-01 Reso... - 4/25/2008 10:04:43 PM
Zeffle
Status: offline
I knew that was going to happen!
LB you should be getting yours soon, Tower has them listed as in stock
       Post #: 85
RE: Going Slow is The Way To Go - Tamiya CR-01 Reso... - 4/26/2008 12:57:45 AM
Lunchboxer
Status: offline
LOL, just checked -> Mine shipped out today!!
       Post #: 86
RE: Going Slow is The Way To Go - Tamiya CR-01 Reso... - 4/27/2008 12:38:55 AM
Zeffle
Status: offline
Just ordered mine!
this should be fun!!
       Post #: 87
RE: Going Slow is The Way To Go - Tamiya CR-01 Reso... - 4/27/2008 12:41:45 AM
Lunchboxer
Status: offline
Great! Be sure to keep us posted with your progress here as well!!
       Post #: 88
RE: Going Slow is The Way To Go - Tamiya CR-01 Reso... - 4/28/2008 10:36:13 PM
Zeffle
Status: offline
LB, have you got yours yet?
Mine isn't going to be here for a few weeks
       Post #: 89
RE: Going Slow is The Way To Go - Tamiya CR-01 Reso... - 4/28/2008 10:41:00 PM
Lunchboxer
Status: offline
UPS says 4/30/08!!
       Post #: 90
