Monocoat color smug
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Tips & Techniques >> Monocoat color smug Page: [1]
Login
Monocoat color smug - 3/23/2008 4:22:22 PM
mgm52
Status: offline
Ok I got the iron too hot applying Monocoat . I assume -- I did not notice the the iron had picked up the blue color ( glue). When I went to the white to touch up some wrinkels, I got the blue on to the white -- How or what do I use to clean the white and get rid of the blue or any other color I screw up and smear. So far no luck, more heat just makes matters worse.
thanks
       Post #: 1
RE: Monocoat color smug - 3/23/2008 5:04:26 PM
Deadeye
Status: online
Acetone outta do the trick.
_____________________________
The USA is not a free country anymore
(in reply to mgm52)
       Post #: 2
RE: Monocoat color smug - 3/23/2008 5:30:22 PM
Jim_Purcha
Status: offline
Make sure you unplug the iron and let it cool off before you use the acertone on it.
(in reply to Deadeye)
       Post #: 3
RE: Monocoat color smug - 3/23/2008 5:41:02 PM
Campy
Status: offline
Acetone will also remove the glue marks from the covering from where the covering shifted slightly during shrinking.
(in reply to Jim_Purcha)
       Post #: 4
RE: Monocoat color smug - 3/23/2008 6:21:59 PM
kamakazie frank
Status: offline
Hey MGM52:
IMO you can't go wrong using Coverite Ironex. It's great for cleaning your iron and getting your monokote clean. I use it more for the monokote cleaning than for the iron and have used it for over 20 years. It's part of my monokote covering procedure. I've just completed the Ultra Sport 40 below.
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by kamakazie frank -- 3/23/2008 6:23:01 PM >
“I have a complex................when I go up everyone comes down.”
AMA #90043....Revver Bro #103
(in reply to mgm52)
       Post #: 5
RE: Monocoat color smug - 3/23/2008 7:18:36 PM
Modelman
Status: offline
CA Debonder works like a charm to clean the seams and your iron. A few drops on a paper towel and you're all set!
C.
"Successful people DO what unsuccessful people don't!"
(in reply to kamakazie frank)
       Post #: 6
RE: Monocoat color smug - 3/23/2008 7:33:37 PM
mgm52
Status: offline
Great ideas guys. It Looks like a common probem, thought it was just me!!!
thanks
(in reply to Modelman)
       Post #: 7
RE: Monocoat color smug - 3/23/2008 7:48:37 PM
Rodney
Status: offline
Isn't CA debonder just acetone with a different label?
(in reply to mgm52)
       Post #: 8
RE: Monocoat color smug - 3/23/2008 10:46:04 PM
DavidAgar
Status: offline
You can also use Monokote trim solvent to clean up your iron and seams. Good Luck, Dave
If the screw ain't loose then things ain't normal.
Dave Agar
AMA#97144
(in reply to Rodney)
       Post #: 9
RE: Monocoat color smug - 3/23/2008 11:49:38 PM
mikegordon10
Status: offline
Here's atip I learned a while back. Put Moneycoat Trim Solvent in a small spray bottle. (I use old CA Kicker spray bottles.) Keep it handy when your covering a model with ANY type of iron on covering. When you need to clean up an edge (even Ultracoat) just give it a little spray and wipe with a paper towel. Trim Solvent is kinda pricey and using it this way makes a bottle last a long, long time. Also cleans up am iron that has accumulated adhisive but like said above it's best to do this to a cold iron.
Mike Gordon AMA 320990
RC Pylon Racing, the ultimate thrill, when sex and drugs just ain''t enough.
(in reply to DavidAgar)
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.563RCU1
