crashcrash
MI, USA Status: offline
quote:
ORIGINAL: paul daniel Hey guys: I just had my L-38 up and it was sort of glitchy. The only thing I've done non-stock is put a 1500 mah battery in it. Because of that, I had to put the receiver up front ahead of the battery and esc. This reciever, a Hitech Electron 6 has not been a problem in the other plane I had which I also flew at the same location. The antenae wire does go past the battery and esc. Is that an issue? Any ideas will help. Paul Paul, I'm running 2 electron 6's, one in an MX-400 helicopter and the other in an EP Glider, the TX is an Eclipse 7. I can tell you that routing the antenna anywhere near the ESC, servo wires, or any other electronics will result in glitching. For some reason, the electron 6's are very sensitive. I also discovered (almost crashing/helicopter) that if you get within 10ft of a power line....you totally loose signal. The Eclipse 7 and the electron 6 work great in planes if the antenna is routed properly and distance of the model isn't a factor unless powerlines are in proximity. You now now what I know.
_____________________________
what?
