gr8taz nitro
MO, USA Status: offline
quote:
ORIGINAL: animal acker Paul, your absolutely right. However, I have encountered some things which I would like to discuss with you all, when cruising along at higher rates of speed the plane seems to wiggle in the air, what's that all about? Also when I do a loop and pull back on the stick too hard when coming out of the loop it sometimes will spin out of control, and I must quickly regain stability. Now I know what your answers will be, if it wants to do that when you pull back that hard, just dont pull back like that, right? I just wondered if anyone else has encountered this, and has anyone had the peice of foam that is held on by magnets above the motor and edf fly off yet? Today as I was really picking up some good speed that thing just blasted off! And those servo protectors under the wings are not very useful, they keep breaking off when I land. Mine does the little tail shimmy also. I generally only see it when I'm cruising around at about 1/2 throttle. It does go away at higher speed. I blew the fan cover off mine on the second flight. I put some clear packing tape over the hatch to keep it in place. That way if I need to get back in there for any reason I can cut the tape and get the hatch off.
_____________________________
If bullets bounced off supermans chest, why did he always duck when they threw the gun at him?
