Axe CP thrusting down instead of up...**Updatedw/video**
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> Helimax >> Axe CP thrusting down instead of up...**Updatedw/video**
Page: [1]
Login
Axe CP thrusting down instead of up...**Updatedw/video** - 3/23/2008 6:27:22 PM
w00derson
Status: offline
I am an RC car guy, so I have no experience with heli's.
Anyway, my dad just bought an Axe CP last week. He stripped out a couple gears in in the servo closest to the front of the heli. He replaced it with a new one (along with some other pieces he broke). He has it all back together now, and instead of thrusting up, its pushing down towards the ground.
What would cause this?
EDIT: Here is a vid: http://www.youtube.com/watch?v=o7EXpgCpmFg
< Message edited by w00derson -- 3/23/2008 9:48:40 PM >
       Post #: 1
RE: Axe CP thrusting down instead of up... - 3/23/2008 7:22:56 PM
COPO
Status: offline
quote:
ORIGINAL: w00derson
I assume you mean it won't lift off? I just went though this an hour ago. Changed blade grips and couldn't get it to lift up at full throttle. After doing some reading here I found that the flybar and main blades need to be level. 0 pitch. Make the flybar level by hand and site down the blades. They probably pitch down. To make them right you need to adjust the linkage that connects to the blade grips.
Check the pitch and set it to 0
(in reply to w00derson)
       Post #: 2
RE: Axe CP thrusting down instead of up... - 3/23/2008 7:44:09 PM
w00derson
Status: offline
I'll have him read that, as I dont know what I'm talking about.
He has the training wheels on it. When you hit the throttle, you can see them actually flexing. Like you can see the training tracking flexing as the heli is pushing down toward the ground.
< Message edited by w00derson -- 3/23/2008 7:46:45 PM >
(in reply to COPO)
       Post #: 3
RE: Axe CP thrusting down instead of up... - 3/23/2008 8:30:40 PM
Shadow99
Status: offline
Did he install the elevator servo (front servo) in correctly?
Did he turn ON the AXE (unplug main & tail motors from 3in1 unit 1st), and allow all the servos to center themselves before installing the servo horn? The servos should be as close to level across the horn as possible when ON and the trims centered.
As the throttle/pitch increases in NORMAL MODE he should see all 3 servos move DOWN about 10 to 15 degrees, applying about 7-9 degrees positive pitch to the blades.
In IDLE-UP MODE, with the throttle at MID-STICK he should have ZERO pitch, at FULL-STICK he should 10 degrees POSITIVE pitch & the opposite at full LOW-STICK about 10 degrees NEGATIVE pitch. See Pics below: First 2 are NORMAL MODE (low & high), other 2 are in IDLE-UP (full + & full -), last 2 pics are of the proper oreintation of the front servo Left & Right sides.
Shadow
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Shadow99 -- 3/23/2008 8:34:42 PM >
_____________________________
"Growing older is MANDATORY... Growing up is OPTIONAL!"
       Post #: 4
RE: Axe CP thrusting down instead of up... - 3/23/2008 9:42:49 PM
w00derson
Status: offline
quote:
ORIGINAL: Shadow99
Shadow
I printed that reply out for him. He's still trying to process what you are saying. In the meantime, here is a video of it.
(in reply to Shadow99)
       Post #: 5
RE: Axe CP thrusting down instead of up...**Updatedw/v... - 3/24/2008 12:29:49 AM
Flying Foot Doc
Status: offline
Did he repalce the servo with the same brand and model? Some servos rotate in different directions. Doc
Trex 450SA In GATOR colors, Raptor 30, I can hover now! JR Airskipper 50 kit next build
       Post #: 6
RE: Axe CP thrusting down instead of up... - 3/24/2008 12:31:37 AM
COPO
Status: offline
quote:
ORIGINAL: w00derson
quote:
ORIGINAL: Shadow99
Shadow
That is what mine was doing. Check the blade pitch. I set mine to 0 and is now back to lifting off the right way. Damn its so hard to control!
       Post #: 7
RE: Axe CP thrusting down instead of up... - 3/24/2008 12:38:50 AM
ucandoitagain
Status: offline
You did exactly what I did, your see saw is upside down. the part that the fly bar is going through
(in reply to COPO)
       Post #: 8
RE: Axe CP thrusting down instead of up... - 3/24/2008 1:50:50 AM
Tall Paul
Status: offline
How the seesaw and pitchlink connects to the blade..
The blade grip connection to the pitchlink to the seesaw is at the -rear- of the blade.
The grip and seesaw will be installed backwards otherwise.
Click for fullsize
Sparky Paul
http://www.angelfire.com/indie/aerostuff
(in reply to ucandoitagain)
       Post #: 9
RE: Axe CP thrusting down instead of up...**Updatedw/v... - 3/24/2008 11:09:57 PM
w00derson
Status: offline
The seesaw was in fact upside down. He's got it all working now. Thanks to everyone for their input.
(in reply to Tall Paul)
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
