Austis -> RE: Allround Glow Fuel? (4/6/2008 11:48:30 AM)
that pinching tecnic is of course just one way of making sure its not to lean.. if you have a cowling that you do not get acces to the fuel line, you can of course use a tac-meter to adjust the engine to a little less than max rpm, or just juse your ear: adjust to you get it to peak rpm then a little richer, so it drops a little in rpms then you fly it. or if you have any other methods, just use them. I have just listed a few. The point I am making is that you have to learn how to proper adjust a engine if you want it to last and perform well. and if you adjust the engine properly, you dont need any castor, cause it dont get that hot that castor does any better lubing than a good synth. cause it wont overheat to extreme temps like they who say that fuel should contain castor oil uses as example. But of course if someone wanna use castor its not wrong doing so, everyone has to use what they feel work, but if the reason for castor use is to protect the engine from hi temps, and lean run, then I am saying that you is better of adjusting it right so you dont overheat it and let it work in a way it is "happy" with.
