No brakes on my E-Firestorm??    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric Off-Road Trucks, Buggies, Truggies and more >> No brakes on my E-Firestorm??
Page: [1]
Login
No brakes on my E-Firestorm?? - 3/24/2008 5:20 AM
allicedout
Score: 121
Last Login: 5/11/2008
Status: offline
OK so it seems I have no brakes on my E-Firestorm. I tried reseting the ESC as one of the members instructed me, but no luck. I do however notice that when its in drive and i hit reverse it rolls to a stop. when I hit reverse and then hit forward it instantly jumps from reverse to forward. Is this normal?? Or is something wrong?? Someone please help me.
Hide Signatures
       Post #: 1
RE: No brakes on my E-Firestorm?? - 3/24/2008 5:24 AM
aftermarket
Score: 100
Last Login: 7/21/2012
Status: offline
You have brakes, just not super brakes, like normal disk brakes. Your electric car rolls to a stop because the motor is the "brake". The esc gives very little power to the motor and it sort of "forces" the car to slow...and the reverse and immediate forward thing is normal. If you get enough traction, you can keep a rolling wheelie Heard it messes up your gears if you over do it. Careful, happy driving!
_____________________________
FrontmotorFrontwheeldrive-03
Hide Signatures
(in reply to allicedout)
       Post #: 2
RE: No brakes on my E-Firestorm?? - 3/24/2008 5:26 AM
allicedout
Score: 121
Status: offline
Good to know. Thank you.
Hide Signatures
(in reply to aftermarket)
       Post #: 3
RE: No brakes on my E-Firestorm?? - 3/24/2008 5:56 AM
hollylx88
Score: 100
Last Login: 3/27/2010
Status: offline
you should have pretty decent brakes. at least enough to lock the rear tires, after all the rears are the only one doing any stopping. my t3 has a little lrp AI and it locks the tires up. and my mamba system in my t4 does too. once the brakes are applied there really is very little weight, so i think you should be able to get decent stopping power.
wa wa woo wa!
Hide Signatures
       Post #: 4
RE: No brakes on my E-Firestorm?? - 3/24/2008 6:00 AM
allicedout
Score: 121
Status: offline
Unfortunately thats not the case. If i'm in forward motion to stop I put it in reverse. This doesn't lock the tires, like I was saying it slowly rolls to a stop. There is no real braking happeneing. If i'm at full speed and I hit the trigger on the radio to reverse to stop it will roll about 5 feet before anything happens. So now I got 2 different opinions. Not sure if the truck is running right or not.
Hide Signatures
(in reply to hollylx88)
       Post #: 5
RE: No brakes on my E-Firestorm?? - 3/24/2008 6:16 AM
hollylx88
Score: 100
Status: offline
the first esc i had in my t3 was like that. it just seemed like there was nothing. then i fried it. but every other electric i've run will stop nice. you said you recalibrated the esc? try calling hpi and see what they say. if its a stock setup, ask around in one of the e-firestorm threats and see if that's how other people's trucks are running
wa wa woo wa!
Hide Signatures
       Post #: 6
RE: No brakes on my E-Firestorm?? - 3/24/2008 6:17 AM
aftermarket
Score: 100
Status: offline
It's right...you still have stubby tires? Good traction on the pavement won't lock up. Your brakes are working, just give yourself room to stop.
Hide Signatures
       Post #: 7
RE: No brakes on my E-Firestorm?? - 3/24/2008 6:24 AM
hollylx88
Score: 100
Status: offline
with those stock holeshot type tires, it should lock up on pavement. i mean if you're questioning whether the brakes accually work or not, somethings wrong.
wa wa woo wa!
Hide Signatures
       Post #: 8
Access
Score: 161
Last Login: 9/29/2011
Status: offline
It's not supposed to lock the tires. There is real braking happening if everything is working right, compare this.
1) Go to full speed, then take your finger off the trigger and let it go into nuetral.
2) Go to full speed, then push the trigger all the way forward (full brake).
Which one takes longer to stop? If they both take the same distance / time, something is wrong.
Either way you are only braking with the rear tires and a 2WD electric isn't going to be able to stop on a dime. That's just the way things are, esp. if you are using the standard motor it's only that strong, so likewise the brakes are only going to be that good.
Locking the tires isn't an optimal way to stop, it's just like with anti-lock brakes (and it would probably also kill the tranny).
Hide Signatures
       Post #: 9
RE: No brakes on my E-Firestorm?? - 3/24/2008 6:38 AM
hollylx88
Score: 100
Status: offline
its not a question of the optimal way to stop. its available breaking force. alls you're doing is dragging the rear tires, so it doesn't take much to lock them up. if you punch it from a stop, the truck spins the tires, right? its not the optimal way to launch the truck, nor is it the best for drive train longevity, but it should have the power there. Having abs in a car would be useless if there wasn't enough braking force to lock the tires up when full brake is applied. if the truck can't lock the tires, or doesn't stop fast enough to the point that you wonder if the brakes even work, somethings not right. whatever power you can put into the motor going forward, you can put in going backwards. whether or not locking the tires stops you any faster, its rwd, and should be able to when full brake is applied. my t3 and t4 both lock up on the pavement, dirt, or whatever else i run them on.
wa wa woo wa!
Hide Signatures
(in reply to Access)
       Post #: 10
RE: No brakes on my E-Firestorm?? - 3/24/2008 6:41 AM
hollylx88
Score: 100
Status: offline
and i'm sure its not programed to give you 100% in a full brake/reverse throttle position. you obviously don't need it. but it should have decent braking force.
wa wa woo wa!
Hide Signatures
       Post #: 11
RE: No brakes on my E-Firestorm?? - 3/24/2008 1:10 PM
savtraxx
Score: 100
Last Login: 6/10/2011
Status: offline
put hydrolics on it =]
Hide Signatures
       Post #: 12
RE: No brakes on my E-Firestorm?? - 5/7/2008 3:35 PM
allicedout
Score: 121
Status: offline
I emailed HPI and all they could tell me to do was send the ESC in, they were no help as far as diagnosing if it was good or bad. Not sure what to do with it.
Hide Signatures
(in reply to savtraxx)
       Post #: 13
RE: No brakes on my E-Firestorm?? - 5/7/2008 3:39 PM
SavageX78
Score: 100
Last Login: 6/30/2008
Status: offline
Maybe its the motor. Thats what the ESC is making stop. Maybe the motor wants to keep going.lol
RCs : XXX-T MF2 ~ Xray M18 ~ Micro-T~ E-maxx 3905 ~ Mardave Cobra ~ Old Lunchbox (needs Restoration)
Hide Signatures
       Post #: 14
RE: No brakes on my E-Firestorm?? - 5/7/2008 3:49 PM
BigTb17
Score: 136
Last Login: 9/23/2012
Status: offline
quote:
ORIGINAL: Access
Did you try this yet? What was the result?
Some ESCs have weaker braking than others. I have had a couple that didn't stop very fast.
Hide Signatures
       Post #: 15
RE: No brakes on my E-Firestorm?? - 5/7/2008 4:53 PM
Dudelive
Score: 100
Last Login: 9/18/2011
Status: offline
quote:
ORIGINAL: BigTb17
quote:
ORIGINAL: Access
Try what Access has posted, the braking is as strong as the motor only. A weak motor will cause longer distance to stop due to the weaker magnets. Some vehicles with stock esc just don't have as good of braking as you want. Also you will get better braking if the rear tires DON'T slide.
ABS = Antilock Braking System....so you will stop better and have better control without locking tires. Real cars will NOT slide the tires with ABS and they stop great.
On a radio control vehicle there are no speed sensors to tell the ABS computer to release some braking force to prevent sliding so they just have the esc programmed to work as ABS and they appear to stop slower and in some cases do.
< Message edited by Dudelive -- 5/7/2008 5:01 PM >
Hide Signatures
(in reply to BigTb17)
       Post #: 16
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.828RCU1
