Spektrum Failsafe
Tower Hobbies
Logged in as Guest
  Printable Version
JR NES703 Low Profile Retract Servo
Seller:  Erick Royer
Details:   $75.00   |  9/2/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> JR Radio & Spektrum Radios Support Forum >> Spektrum Failsafe
Page: [1]
Login
Spektrum Failsafe - 3/24/2008 9:56:38 PM
TheShirt
Status: offline
Is there any way to turn off the throttle failsafe when using a Spektrum Airmod?
       Post #: 1
RE: Spektrum Failsafe - 3/24/2008 10:08:12 PM
krayzc-RCU
Status: offline
set it to hold or put it in your desired spot using the clear feature
_____________________________
smooth as silk!
(in reply to TheShirt)
       Post #: 2
RE: Spektrum Failsafe - 3/24/2008 10:13:59 PM
TheShirt
Status: offline
OK, but don't want it to activate at all. Any ideas?
(in reply to krayzc-RCU)
       Post #: 3
RE: Spektrum Failsafe - 3/24/2008 11:20:36 PM
krayzc-RCU
Status: offline
u do not want it to move from its present location if u run info fail safe? is that correct or do u want it to go to idle in fail safe?
smooth as silk!
       Post #: 4
RE: Spektrum Failsafe - 3/24/2008 11:39:34 PM
TheShirt
Status: offline
I don't want it to move if possible
       Post #: 5
RE: Spektrum Failsafe - 3/25/2008 12:02:40 AM
krayzc-RCU
Status: offline
choose the hold option one setting is up the other is down it reads hold on one direction and failsafe or FS on the other option choose this for the throttle as you will also see u have those optoons under all surfaces ie rudder, elevator, ailerons, gear.....and so forth
smooth as silk!
       Post #: 6
RE: Spektrum Failsafe - 3/25/2008 12:55:11 AM
TheShirt
Status: offline
Got it - Thanks
       Post #: 7
RE: Spektrum Failsafe - 3/25/2008 1:52:18 AM
krayzc-RCU
Status: offline
u r welcome i suppose all of this will be deleted once JR comes on to the site
smooth as silk!
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.797RCU1
