Caliber 3 with Irvine .39
Tower Hobbies
Logged in as Guest
  Printable Version
TREX 700 Nitro for sale - RTF
Seller:  JRSmith
Details:   $2,150.00   |  10/8/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Helicopters >> Kyosho Helicopters >> Caliber 3 with Irvine .39
Page: [1]
Login
Caliber 3 with Irvine .39 - 3/25/2008 2:17:22 PM
janfloirs
Status: offline
Hi
Does anyone have any experience with a Irvine .39 motor on a Caliber 3? I am struggeling a bit to keep the headspeed constant during flight. (Only "up and down" hover at this stage). My pitch curves are -4, 4 and 9 for normal flight. I don't bother with Idle up 1 at this stage because of the motor not running as it should. I have a JR 2610 radio. At half throttle the engine sounds fine, but as I increase the pitch a little to almost 3/4, the revs drop. When I pull the stick down again, the revs increase and it sounds as if the engine reaches peak. (If you can call it peak at 60% throttle). My throttle curve is 20, 50, 60, 70, 100 for noraml mode. I am new to nitro helis, so I dont have much experience in setting the engine and knowing all of the sounds it should make. I have been flying airplanes for a few years, but my problem with the heli eninges is that unlike an airplane enige, you can't rev it up to full thorttle to hear if it peaks or not... . I suspect that the problem might lie with the low end tuning, but I'm not sure. Any comments will help. Thnks
_____________________________
_____________
Cheers
       Post #: 1
RE: Caliber 3 with Irvine .39 - 3/25/2008 2:47:40 PM
Cyberfyn
Status: offline
Sounds like a mixture problem. Does the engine produce a lot of smoke and splutter when it loses power?
Ian F.
Very funny Scotty, Now please beam down my clothes!
(in reply to janfloirs)
       Post #: 2
RE: Caliber 3 with Irvine .39 - 7/3/2008 10:34:32 AM
janfloirs
Status: offline
Yes it does. If you bump full collective while in a hover the rmp (and obviously headspeed) drops.
_____________
Cheers
(in reply to Cyberfyn)
       Post #: 3
RE: Caliber 3 with Irvine .39 - 7/4/2008 12:46:48 PM
Cyberfyn
Status: offline
First, try turning the main needle in by half a turn (clockwise) and see if that helps. You could also re-set the main needle to two and a half turns out from closed and go from there.
Ian F.
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.750RCU1
