RE: Zippkits Rockett hydro build
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Boats >> Speed - RC Gas Boats >> RE: Zippkits Rockett hydro build
Page: <<   < prev  1 [2] 3 4 5 6 7 8 9 10   next >   >>
Login
RE: Zippkits Rockett hydro build - 3/26/2008 2:30:31 PM
martno1fan
Status: offline
Hi guys thanks for all the kind comments ill be sure to keep you all updated on my progress,nothing much to report today,got all the frames epoxied to the bottom now so its left to set .As for the motor it will be a modded zen which should push it pretty well all been well.Im getting it from Ken cheers mate its used but only recently modded ,heres a link to one its the ss modded one.I havent decided on a pipe setup for it yet,will be a 90% header though pluss i will need to extend the pipe after the stinger to exit the transome this will be done using some ali tube and a silicon flex coupling.Thats the standard setup for these boats apparently,no the extension doesnt alter the tuned length so long as its after the stinger or muffler and the tubes not narrower than the muffler .
http://gasrcproducts.moonfruit.com/#/modmotors/4526479367
_____________________________
im not argumentative im just missunderstood
(in reply to fuelman8)
       Post #: 26
RE: Zippkits Rockett hydro build - 3/26/2008 2:59:32 PM
glennb2006
Status: offline
Mart maybe one of the pipes we have here, the CS23 or similar, being a bit longer with the silencing section would fit nice to let the end of the pipe out the back without having to extend it. Same one as Brod is running now, maybe measure his up to see if it'll go in there OK?
Glenn
(in reply to martno1fan)
       Post #: 27
RE: Zippkits Rockett hydro build - 3/26/2008 3:10:17 PM
martno1fan
Status: offline
never thought of that mate allready have his old one here ill have alook see,i also have a rossi pipe but not sure how that would perform on a modded motor,they run ok on stockers apparently what you reckon?its about same length as daves pipes.
< Message edited by martno1fan -- 3/26/2008 3:11:34 PM >
(in reply to glennb2006)
       Post #: 28
RE: Zippkits Rockett hydro build - 3/26/2008 3:16:32 PM
glennb2006
Status: offline
I would stick with a pipe designed for petrol motors, the rossi pipe will be off a glow motor and I suspect the expansion chamber volume will be smaller. If it is a tuned motor you are fitting then I would go for the CS23 pipe or similar.
Glenn
       Post #: 29
RE: Zippkits Rockett hydro build - 3/26/2008 3:19:34 PM
martno1fan
Status: offline
well its a .90 pipe but was also listed as for use on zenoah motors,i got it cheap for the weedy motor but its only been used once had problems with the header so took it off.i know the guy who i got it from has used them on zens and sikks but your probably right.
       Post #: 30
RE: Zippkits Rockett hydro build - 3/26/2008 5:39:37 PM
wayneuk01
Status: offline
its looking good mart
       Post #: 31
RE: Zippkits Rockett hydro build - 3/26/2008 5:46:03 PM
martno1fan
Status: offline
quote:
ORIGINAL: wayneuk01
Cheers mate ,its the waiting for the epoxy to cure thats the hard bit the kits a doddle so far .
Mart
(in reply to wayneuk01)
       Post #: 32
RE: Zippkits Rockett hydro build - 3/27/2008 6:46:33 AM
bentley marshall
Status: offline
come on mart ya slacking is it finished yet
       Post #: 33
RE: Zippkits Rockett hydro build - 3/27/2008 10:17:02 AM
martno1fan
Status: offline
Listen to speedy gonzales ,ill do a bit more today once the cabin warms up (workshop) epoxy wont cure in the cold and its cold here,suposed to be spring but i dont see any signs of it yet .ill put the sponson strin gers in today and the engine rails.
Mart
(in reply to bentley marshall)
       Post #: 34
RE: Zippkits Rockett hydro build - 3/27/2008 12:16:18 PM
martno1fan
Status: offline
Well i got the sponson chine rails added and the engine rails in and weighted down so im waiting for those to dry right now,thats the worst thing about the build all the waiting .
mart
Click to see fullsize image.
Click for fullsize
       Post #: 35
RE: Zippkits Rockett hydro build - 3/27/2008 2:52:33 PM
Doubledog
Status: offline
Bro, just toss a keg of beer on there & be done with it. You've got a Brick... belt sander, .... can of paint
Some village lost their idiot. Are you it?
       Post #: 36
RE: Zippkits Rockett hydro build - 3/27/2008 2:58:34 PM
martno1fan
Status: offline
Jamie the beers for drinking lol,the weights needed to keep things flat to the bottom while gluing if id had two concrete blocks id have used them but couldnt find another .Should get the sponson sides and bottom on tomorrow,no rush .Im also thinking of a side exit for the exhaust instead of out the back,ill just use part of an old header as a bend to exit.
Mart
(in reply to Doubledog)
       Post #: 37
RE: Zippkits Rockett hydro build - 3/27/2008 5:54:22 PM
Doubledog
Status: offline
LOL. Speaking of beer.... I'm out. Looks like a sip of Chivas instead. I need a chill pill tonight.
       Post #: 38
RE: Zippkits Rockett hydro build - 3/28/2008 12:13:33 AM
ken0276
Status: offline
wow your hydro seems to need a lot of work to build it up then paint it, does it come with a set up instruction for the CG and etc? how many Lbs does its weigh?
       Post #: 39
RE: Zippkits Rockett hydro build - 3/28/2008 12:58:19 AM
dwr9
Status: offline
You're really movin right along on this one Mart. Lookin good. Doug
(in reply to ken0276)
       Post #: 40
RE: Zippkits Rockett hydro build - 3/28/2008 1:50:36 AM
Hydro Junkie
