brodjack
Joined: 9/25/2004 From: Blackpool, UNITED KINGDOM Status: offline
quote:
ORIGINAL: martno1fan Your a funny guy Glenn,usually thats what i do actually but so far what you see is 2 hrs of actual building time and about 18 hrs of waiting time for glue to set .Yes it goes together very quick so quick in fact ill need to stop untill i get further items to continue.Ill need to fit the tube, motor ,exhaust ,tank etc before i sheet the deck just so i have room to work,ill also need to make sure i can get access to things once the decks on but im not worried as the opening is quite large when you remove the cowling.Only have an 18" ready made flex and stub and ill need a 30 " one any ideas?,ive looked on Daves site doesnt seem he has any but ive emailed him in case.Maybe he will swap me this one for a longer one its brand new ,the tube needs to be long too probably about 26-27" not sure if they will have any at B&Q ,might be worth a look though will save a bit on postage on a 3 ft tube . Hydro sorry dont know your real name?,dont worry about the sponsons mate no water will be getting in there i will be glassing the insides of them also i will fill them with foam before sheeting the top.Thanks for the heads up though i do see your point ,feel free to say what you think if you have a better idea im allways willing to listen. Mart I thought Daves was too expensive, Mart??? Brod...
_____________________________
Nothing is impossible,so never,ever, give up.........
