Joe Lott
AL, USA Status: offline
I seriously thought about using a cylinder to actuate my tail wheel, to the point of buying the cylinder. I decided in the end to use a servo instead. I just thought that fewer air connections might limit the possibility of an air leak. I had my air valve and servo on the main servo tray, but moved it to the wing center, since I decided not to use the tail wheel cylinder. I was also going to mount the tail wheel cylinder @ the cockpit deck, and screw a 2-56 rod into the end of it to actuate the tail wheel. As for tail wheel steering, I just y'd a servo with the rudder servo, located it @ F8 and used 50 lb monofilament with clevises at the servo and tail wheel steering actuator. When the wheel is up, there is enough slack in the pull-pull cables to keep wheel from moving.
