marcoferretti -> RE: top flite corsair build questions (5/13/2008 9:06:54 AM)
This is how the wing-saddle looks like on my Corsair. There's still a lot of sanding and finishing to do, but I'm very satisfied about this build. I have seen many .60 Top-Flite Corsairs built with gear doors on both main and tail, in addition, these models had a glass finish.... but what about weight? It is true that this is a fast plane, but over-weighting does increase stall-speed and will make it more difficoult to handle during take-offs and landings. What is your opinion about this? Mistral, what is your expected weight? I expect a maximum of 8.8 / 9 lb with Saito Fa125 engine, mains+tail retracts (no doors - pics...), flaps. I tried to make the lightest build as I could. My finish will be a "modelspand" cover (that kind of paper made of 40% silk, 60% paper, only 12g per square meter!), it is applied to the body with conventional acetone based sanding primer. The result is a very smooth and hard surface but it is not as robust as a glassing would be. This is the lightest covering I know...
