Sturdy Birdy on Floats
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Seaplanes >> Sturdy Birdy on Floats Page: [1]
Login
Sturdy Birdy on Floats - 3/26/2008 12:21:54 AM
Bad Tooth
Status: offline
What do you guys think? Will this work? I'd prefer to not move my main gear and just add another in the back, is the one in the back too far?
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 1
RE: Sturdy Birdy on Floats - 3/26/2008 12:23:09 AM
Bad Tooth
Status: offline
Also what about the down angle on the engine? Will that be a big problem?
(in reply to Bad Tooth)
       Post #: 2
RE: Sturdy Birdy on Floats - 3/26/2008 11:49:33 PM
David Mosher
Status: offline
My 2cents: CofG over step. Yes, incidence of engine a concern. While all things can be adjusted and compensated for, it is not going to set you up for success. Wing incidence needs to be considered also. Plane will either balloon or sink like a stone when throttle backed off, depending on relationship with wing. get that engine straightened up, it will save you grief.....
       Post #: 3
RE: Sturdy Birdy on Floats - 3/27/2008 1:58:17 AM
JimCasey
Status: offline
Downthrust is common, especially with trainers. The principal source of drag is the wing. Adding power below the wing causes a moment that lifts the nose. A little downthrust as you have it makes the plane fly straighter. It probably has the engine pointing a little to the right, also.
My Senior kadet has 6 degrees of downthrust. Even full-size planes use it: Here's a T-28
< Message edited by JimCasey -- 3/27/2008 2:00:37 AM >
_____________________________
Jim Casey/Seaplane Nerd
http://www.smilesandwags.com/Floats.html
(in reply to David Mosher)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.359RCU1
