RE: Tamiya Pajero-Collective Build    Gallery
Logged in as Guest
    Search This Thread
Printable Version
SCT Combo - RTR
Seller:  Callifas38
Details:   $100.00   |  5/19/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric Off-Road Trucks, Buggies, Truggies and more >> RE: Tamiya Pajero-Collective Build
Page: <<   < prev  31 32 33 34 35 36 [37] 38 39 40   next >   >>
Login
RE: Tamiya Pajero-Collective Build - 2/24/2009 4:26 PM
Lunchboxer
Score: 436
Last Login: 5/22/2013
Status: offline
Why don't you want to glue the tires?!?
_____________________________
LB | WW2 | TLT | TB02 | DF03 | TEgg | F103GT | TXT | Hornet | Frog | Scalpel | Leo 2A6 | Aeromax | WW1 | Clod | CR-01
Hide Signatures
(in reply to Bok)
       Post #: 901
RE: Tamiya Pajero-Collective Build - 2/24/2009 5:12 PM
Bok
Score: 105
Last Login: 2/23/2012
Status: offline
quote:
ORIGINAL: Lunchboxer
Cause I'm cheap And the amount of sand and dirt that can get inside the tires is unbelievable... If i glue them on then I won't be able to drain them out. Anyway I tried using some thin double-sided tape. The tires don't slip now They should hold up when crawling, but once I hit the sand again I think the tape will lose its grip...
Tamiya TA02, Stadium Thunder, TT01D Type E, CR01, CC01, M03L, TA05 v2 R
Hide Signatures
(in reply to Lunchboxer)
       Post #: 902
RE: Tamiya Pajero-Collective Build - 2/24/2009 5:58 PM
Lunchboxer
Score: 436
Status: offline
Sand and dirt gets inside even when you glued them? I think it is pretty hard to get the sand inside if you actually glued the tires...
Hide Signatures
(in reply to Bok)
       Post #: 903
cornel4web
Score: 100
Last Login: 2/21/2013
Status: offline
how the sand will get inside if the tires are glued...or you think at spot glued
MP,TLT-1,CLOD,WW2,TA04S,Jugg2,TT01D,cc/xc''s,M03/M04,spider G-made,F201,F103,TB-01
Hide Signatures
(in reply to Bok)
       Post #: 904
RE: Tamiya Pajero-Collective Build - 2/24/2009 7:58 PM
Bok
Score: 105
Status: offline
There is a vent hole on each wheel. The sand can still enter through there if you find yourself in a situation like this..
And in my CR-01 sand and dirt still get inside the tires...
< Message edited by Bok -- 2/24/2009 8:05 PM >
Hide Signatures
(in reply to cornel4web)
       Post #: 905
RE: Tamiya Pajero-Collective Build - 2/24/2009 9:35 PM
cornel4web
Score: 100
Status: offline
LOL...you are right...best photo for starting some PP... bluring the background will make it nicer...
Hide Signatures
(in reply to Bok)
       Post #: 906
RE: Tamiya Pajero-Collective Build - 2/25/2009 6:06 AM
manerdie
Score: 100
Last Login: 4/15/2009
Status: offline
it was not a hard core crawler modification, though it is now more capable than stock, we focused on protecting the plastic parts and addressed all the weak points. no body/shell lift was done to retain the scale look
modifications were made by edward's custom crawler here in the philippines http://edward531.proboards58.com/
modifications:
Lifted front suspension using aluminum mounting blocks(just like the ones used in 1:1) about 4mm gained lift
extended aluminum skidplate(integrated with the stock bumpers)
driveline protection up to the transfer case
extended front dogbones
rear four link suspension with axle stiffeners(no more plastic links and trailing arms)
compact rear axle skid plate
aluminum spare tire mounting
90wt shock oil
litium grease into servo output gear(waterproof)
locked rear diff
then i used some lock to lock plasticware for my receiver and esc, i used gram lights 6mm offset wheels(extra) paired with hi-lift tires, finally i trimmed a bit of the fender so that the tires wouldnt rub in it.
and for the light kit, i used strobe lights in the headlights and fog lights. then installed aditional two bucket lights inside the front grill which is alternating then red and blue strobes inside the front window to complete the police look(here in the philippines alot of our congressmen and senators uses the pajero as their back up or escort vehicle)
< Message edited by manerdie -- 2/25/2009 6:22 AM >
Hide Signatures
       Post #: 907
RE: Tamiya Pajero-Collective Build - 2/25/2009 7:08 PM
Bok
Score: 105
Status: offline
Tore the Pajero apart for routine maintenance. When I opened up the rear axle, sand came pouring out!! Seems strange that only one side got filled up. Will have to find a way to keep the dirt out.. any suggestions?
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to manerdie)
       Post #: 908
RE: Tamiya Pajero-Collective Build - 2/26/2009 10:04 AM
cornel4web
Score: 100
Status: offline
already discontinued ????
http://www.tamiyausa.com/product/item.php?product-id=49490
Hide Signatures
(in reply to Bok)
       Post #: 909
RE: Tamiya Pajero-Collective Build - 2/26/2009 11:56 AM
Lunchboxer
Score: 436
Status: offline
Geez.. so fast!!
Better keep the 2 I still got, huh?!
Hide Signatures
       Post #: 910
RE: Tamiya Pajero-Collective Build - 2/26/2009 2:39 PM
The Collector1
Score: 195
Last Login: 5/21/2013
Status: offline
Wow, oh well I still have two, need to finish the one Im doing now and leave the other one NIB
Avante2011,Tundra,TT01,Amax,Blackfoot,MB,Hilux Racer,Durga,TA01,02,03,Nitrage5.2,959,E801XT,801X,RC8 Family,and alot more
Hide Signatures
       Post #: 911
RE: Tamiya Pajero-Collective Build - 2/27/2009 11:08 PM
cornel4web
Score: 100
Status: offline
still in stock at tower...
Hide Signatures
(in reply to The Collector1)
       Post #: 912
RE: Tamiya Pajero-Collective Build - 2/27/2009 11:10 PM
Lunchboxer
Score: 436
Status: offline
Yeah, buy them while they are still available! I was told by my supplier that he can't get them anymore... !!
Hide Signatures
       Post #: 913
RE: Tamiya Pajero-Collective Build - 2/28/2009 7:56 AM
48chebbie
Score: 100
Last Login: 5/13/2013
Status: offline
same here lunchboxer. mine says they are no longer available to him. omni models still has a few on hand.............
don''''t sweat the petty things...........
pet the sweaty things...........
Hide Signatures
       Post #: 914
RE: Tamiya Pajero-Collective Build - 2/28/2009 8:28 AM
secretsg
Score: 121
Last Login: 5/16/2013
Status: offline
Looks XB is available soon? That makes no sense. They are still making the shell obviously.
There is NO best anything in RC. No one CARES about what is the fastest. Asking same question a million times WON''T help.
Hide Signatures
(in reply to 48chebbie)
       Post #: 915
RE: Tamiya Pajero-Collective Build - 2/28/2009 11:12 AM
cornel4web
Score: 100
Status: offline
not for long...I'm set, having one NIB and an extra shell (thnx to TEX)...
Hide Signatures
(in reply to secretsg)
       Post #: 916
RE: Tamiya Pajero-Collective Build - 2/28/2009 1:52 PM
The Collector1
Score: 195
Status: offline
quote:
ORIGINAL: cornel4web
Nope now they are on order, and knowing them it will say discontinued next
Hide Signatures
       Post #: 917
RE: Tamiya Pajero-Collective Build - 2/28/2009 4:35 PM
cornel4web
Score: 100
Status: offline
that means LB make an order from tower and finish them all...LOL..
Hide Signatures
       Post #: 918
RE: Tamiya Pajero-Collective Build - 2/28/2009 8:28 PM
Kitsune
Score: 161
Last Login: 5/5/2013
Status: offline
Hmm... would anybody be interested in a mount for a real spare on the it?
Trying to get ideas for stuff to build.
"If you have 10,000 regulations, you destroy all respect for the law." -Winston Churchill
Hide Signatures
       Post #: 919
RE: Tamiya Pajero-Collective Build - 3/1/2009 12:02 AM
cornel4web
Score: 100
Status: offline
this can be done easy...direct screw...
Hide Signatures
(in reply to Kitsune)
       Post #: 920
RE: Tamiya Pajero-Collective Build - 3/1/2009 1:00 AM
Kitsune
Score: 161
Status: offline
I finally got mine done.
Click for fullsize
Hide Signatures
       Post #: 921
RE: Tamiya Pajero-Collective Build - 3/1/2009 4:06 AM
jncwhite
Score: 100
Last Login: 4/27/2009
Status: offline
i am
Hide Signatures
       Post #: 922
RE: Tamiya Pajero-Collective Build - 3/1/2009 7:14 AM
Lunchboxer
Score: 436
Status: offline
Junfac makes one.. you can take a look at that to compare to what you have in mind!!
quote:
ORIGINAL: Kitsune
Hide Signatures
       Post #: 923
RE: Tamiya Pajero-Collective Build - 3/1/2009 4:47 PM
The Collector1
Score: 195
Status: offline
Working on mine as I type , I really need to finish this so I can start on another project
Hide Signatures
       Post #: 924
RE: Tamiya Pajero-Collective Build - 3/4/2009 11:26 PM
The Collector1
Score: 195
Status: offline
Finished the body finally, installed universals and a receiver, now to work on the 4 link heres some pics
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 925
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.453RCU1
