RE: Tamiya Pajero-Collective Build    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric Off-Road Trucks, Buggies, Truggies and more >> RE: Tamiya Pajero-Collective Build
Page: <<   < prev  31 32 33 34 35 36 37 [38] 39 40   next >   >>
Login
RE: Tamiya Pajero-Collective Build - 3/4/2009 11:29 PM
The Collector1
Score: 195
Last Login: 6/18/2013
Status: offline
A size difference between my jero, my F1 and my Amax
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
Avante2011,Tundra,TT01,Amax,Blackfoot,MB,Hilux Racer,Durga,TA01,02,03,Nitrage5.2,959,E801XT,801X,RC8 Family,and alot more
Hide Signatures
(in reply to The Collector1)
       Post #: 926
RE: Tamiya Pajero-Collective Build - 3/5/2009 12:08 AM
The Collector1
Score: 195
Status: offline
The semi is a 1/14 scale btw
Hide Signatures
       Post #: 927
RE: Tamiya Pajero-Collective Build - 3/8/2009 3:14 PM
Bok
Score: 105
Last Login: 2/23/2012
Status: offline
had a small get together today
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Tamiya TA02, Stadium Thunder, TT01D Type E, CR01, CC01, M03L, TA05 v2 R
Hide Signatures
       Post #: 928
RE: Tamiya Pajero-Collective Build - 3/8/2009 10:57 PM
The Collector1
Score: 195
Status: offline
Looking good bok, how do those tires hook up?
Hide Signatures
(in reply to Bok)
       Post #: 929
RE: Tamiya Pajero-Collective Build - 3/9/2009 10:00 AM
Bok
Score: 105
Status: offline
Thanks Collector1! The high lift tires hook up pretty well on the rocks, with locked front and rear diffs I barely saw them slip. But they don't hook up well when climbing loose dirt and sand. Don't know how they compare with the stock tires as I put these on right after I completed my build
Hide Signatures
       Post #: 930
RE: Tamiya Pajero-Collective Build - 3/9/2009 12:43 PM
manerdie
Score: 100
Last Login: 4/15/2009
Status: offline
Thats was a great run bok..hahaha...i told you that place rocks...more trail runs and rally cross to come guys..too bad we didnt take pictures when we are climbing that almost 6 ft sand trail(formed into a mini mountain or scale mountain..hehehe)
By the way who can sell me a spare cc-01 spur gear? Mine got busted(because of my own fault) so i need one asap...thanks..
Hide Signatures
(in reply to Bok)
       Post #: 931
RE: Tamiya Pajero-Collective Build - 3/9/2009 1:18 PM
cornel4web
Score: 100
Last Login: 2/21/2013
Status: offline
how's that???...the trainy are pretty buletproof...which part you broke?
MP,TLT-1,CLOD,WW2,TA04S,Jugg2,TT01D,cc/xc''s,M03/M04,spider G-made,F201,F103,TB-01
Hide Signatures
(in reply to manerdie)
       Post #: 932
RE: Tamiya Pajero-Collective Build - 3/9/2009 5:34 PM
manerdie
Score: 100
Status: offline
i opened the tranny case after a run then run it again, i think a loose debris went inbetween the pinion and spur gear after openening it...it does work but it has a cracking sound..
Hide Signatures
(in reply to cornel4web)
       Post #: 933
RE: Tamiya Pajero-Collective Build - 3/9/2009 6:02 PM
Bok
Score: 105
Status: offline
Could you show us a picture of your tranny? Maybe something is just loose inside
Hide Signatures
       Post #: 934
RE: Tamiya Pajero-Collective Build - 3/9/2009 6:04 PM
manerdie
Score: 100
Status: offline
nothing is loose, spur is damage a bit...i need to find some G parts
Hide Signatures
(in reply to Bok)
       Post #: 935
RE: Tamiya Pajero-Collective Build - 3/9/2009 6:08 PM
Lunchboxer
Score: 436
Status: offline
I think you should open it up and make sure you clean everything out.. a lot of time the clicking sound is from a sand that got stuck between the teeth... so look for them!
LB | WW2 | TLT | TB02 | DF03 | TEgg | F103GT | TXT | Hornet | Frog | Scalpel | Leo 2A6 | Aeromax | WW1 | Clod | CR-01
Hide Signatures
       Post #: 936
RE: Tamiya Pajero-Collective Build - 3/9/2009 6:19 PM
Bok
Score: 105
Status: offline
Yup I would try cleaning the gears and bearings inside the tranny. Use a toothbrush and soapy water to clean the gears. Don't forget to grease them when you reassemble everything.
Hide Signatures
(in reply to Lunchboxer)
       Post #: 937
RE: Tamiya Pajero-Collective Build - 3/10/2009 3:34 PM
Bok
Score: 105
Status: offline
Was able to work on the Pajero today. Replaced the sloppy lower trailing arms with aluminum ones from my CR-01. Upgraded the CR-01 to bent links, so I had these lying around Will tackle the upper arms next...
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Bok)
       Post #: 938
RE: Tamiya Pajero-Collective Build - 3/19/2009 4:39 PM
HondaFun
Score: 100
Last Login: 2/20/2012
Status: offline
Hi,
I have one too, mine is the first version which i bought it in 1993. I have recently bought a new body kit (the original one is pretty much destroyed) and convert it into the low ride conversion set. It has full ball bearings, ESC, RS540 motor, lock diff.
Pajero are very strong cars. Mine is around 15 years old and runs perfectly.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Bok)
       Post #: 939
RE: Tamiya Pajero-Collective Build - 3/20/2009 10:49 AM
ramp4ge
Score: 100
Last Login: 8/19/2011
Status: offline
My 'Jero.
Fifty-Five/XL5/"Wolfpack" 3000MAh.
Full bearings.
Full hex hardware.
Associated buggy front shocks on the rear, waiting for the fronts to come on. Apparently Tower only had 1 set. Got the AE springs up front tho.
Waiting on some Trail Docs.
Paint was actually a "prototype" and color-testing for this:
When my 10th scale H3 gets here.
< Message edited by ramp4ge -- 3/20/2009 11:13 AM >
Hide Signatures
(in reply to HondaFun)
       Post #: 940
RE: Tamiya Pajero-Collective Build - 4/23/2009 12:59 AM
cbs52
Score: 100
Status: offline
Got mine very wet the other day, so I decided to take it apart and clean it before any bearings seized. Took the receiver out of its balloon only to find that it was quite wet - ooops. Decided to get a plastic box to fit the receiver in to avoid this trouble in future - see the photos for how I fitted it. Also fitted my old Demon triple 17 turn motor to see how it goes - will find out tomorrow...
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to ramp4ge)
       Post #: 941
RE: Tamiya Pajero-Collective Build - 4/23/2009 1:33 AM
The Collector1
Score: 195
Status: offline
Get some waterproof grease and put it on all the threads of the screws that go into the case and around the opening of the case
Hide Signatures
(in reply to cbs52)
       Post #: 942
RE: Tamiya Pajero-Collective Build - 4/23/2009 4:37 PM
cbs52
Score: 100
Status: offline
quote:
ORIGINAL: The Collector1
Thanks, I will, or at least make a gasket of some sort and find a suitable grommet to seal around the wires. I am actually going to redrill the holes in the base as it needs to go back a bit to be more solid (and I got them in slightly the wrong place to start with). At the moment it's warm and sunny here, so there's no rush...
Hide Signatures
       Post #: 943
RE: Tamiya Pajero-Collective Build - 4/23/2009 8:37 PM
cbs52
Score: 100
Status: offline
Well, the Demon motor has noticeably less torque so there's less wheelspin and less acceleration from standstill, but it is noticeably faster at the top end. Almost too fast for the chassis really. On loose surfaces, makes it more entertaining as it is easier to drift and spin. Motor does get warmer than the silvercan.
Hide Signatures
(in reply to cbs52)
       Post #: 944
RE: Tamiya Pajero-Collective Build - 4/24/2009 1:01 AM
engineerjoe
Score: 100
Last Login: 2/8/2011
Status: offline
well, i guess I'll post up some pics of mine.
35T motor
sidewinder running on 4s A123 (13.2V) FASSSTTTT!!!
Losi Mini Crawler shocks in the rear for more articulation
pics are frome various stages of the build
added a snorkel
Hide Signatures
(in reply to cbs52)
       Post #: 945
RE: Tamiya Pajero-Collective Build - 4/28/2009 11:36 PM
cbs52
Score: 100
Status: offline
Nice pics engineerjoe, and what a great place to run! I see your bodyshell is looking like it has seen some action, but then if you are running it fast, it does tip over more as I am finding with a modified motor in mine.
Have resited the receiver box that I added to make it more stable, as you can see from the pictures below, before first then after. You might also notice that despite not wanting to get it dirty again, it is...
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to engineerjoe)
       Post #: 946
RE: Tamiya Pajero-Collective Build - 4/29/2009 5:59 AM
Andyjk
Score: 105
Last Login: 4/27/2013
Status: offline
Hey everyone, wow some awsome pics. I love the scale realism of this car.
Just wondering if anyone knows the part numbers for the stock wheels and tyres that come with the Pajero?
Any help greatly appreciated!
RS4 3 Evo-Elec., E-Sav, TT-01, DF-01, Slash, CC-01, M-05, M-04, TT-01Ra, HZ Champ, HZ Super Cub, Turnigy 118B, 2x Dark Impac
Hide Signatures
(in reply to cbs52)
       Post #: 947
RE: Tamiya Pajero-Collective Build - 4/30/2009 4:28 AM
The Collector1
Score: 195
Status: offline
Hey Andyjk, the part numbers are 0445516 for the wheels and 9805561 for the tires
Hide Signatures
(in reply to Andyjk)
       Post #: 948
RE: Tamiya Pajero-Collective Build - 4/30/2009 4:51 AM
Andyjk
Score: 105
Status: offline
oh awesome thanks heaps!!!!
Hide Signatures
       Post #: 949
RE: Tamiya Pajero-Collective Build - 4/30/2009 11:29 PM
The Collector1
Score: 195
Status: offline
No problem Andyjk, heres a couple of pics with a working winch I just installed, the winch is controlled by the 3rd channel on my 3PK
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by The Collector1 -- 4/30/2009 11:30 PM >
Hide Signatures
       Post #: 950
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.766RCU1
