nitro _ burner
Joined: 1/18/2007 From: adelaide, AUSTRALIA Status: offline
quote:
ORIGINAL: Wheelnut quote:
ORIGINAL: nitro _ burner Thanks for the advice! I would go with somthing like a 13T motor but the ESC is rated for 19T or more. The sub C cells are equal in the way that two of them side by side are the same width as one of their lenghts. Does that make sence? its the same with the 2/3AA Baterys used in minis. Yeh, well ill forget the motor, but im going to need a new battery pack eventually so ill get them for now... i just need to choose one... BTW, i just remembered, the CC BL systems are brushed compatible, with unlimited T, so if i get the BL system and ever change my mind... If the side by side sub C's are put together with quality battery bars the are a good bit wider. I have learned this lesson in other cars of mine. Good idea, get the batteries for now, and the esc when you are ready. There is not a huge difference in the price of brusless or modified quality brushed motors. The big difference in price is the esc. Yeh, ive notised that, that is why i was hesitant. The sidewinder is a cheap BL ESC that can support brushed, so ill be getting the best of both worlds!
_____________________________
RC''s: BL Mini B, Micro B, BL RC18T, CEN ME16MT and an LST2!!!
