Beomagi
Joined: 1/3/2006 From: Bayonne, NJ, USA Status: offline
quote:
ORIGINAL: derSleeper What I don't get: The motor says: 13,5T brushless. Which would be like 23T brushed. So would that mean that a 12-14t brushed motor is a lot faster than a 13,5T brushless motor? Don't know really, but a slow brushless will be slower than a fast brushless of course. It comes down to the power draw. You can't expect to be faster them a motor that converts more power into kinetic energy. If you have a 300 watt brushless motor that's 90% efficient (270W to kinetic) and go up against a 60% efficient 600 watt brushed motor (360W to kinetic) you will lose. Your motor will be more efficient, generate less heat, and can therefore last longer on the same battery, or even gear higher, but you're at it's limit. LRP makes all the way down to 3.5 turns. Right now, you actually have a fairly weak 540 brushless motor - even though it's 540, it's only 200watts or so (at 7.2v). It's a GREAT motor for runtimes, and should be nippy enough at 3200kv (the lrp 13.5), but understand that high kv with low watts (and therefore low amps pulled) means less torque. if you pull that same kv at say 600W, your motor will be capable of a much bigger pinion. Experiment and determine what's best for you. Do note - lower kv/higher turn motors have somewhat more potential, since the motors can handle higher voltage. If you think it's slow, add volts via lithium or more cells if you can fit it. Beware of being limited by the ESC.
< Message edited by Beomagi -- 6/3/2008 6:12:49 PM >
