RE: All Composite 1/7th P-40E Mould Build    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Composites Fabrication And Repair >> RE: All Composite 1/7th P-40E Mould Build Page: <<   < prev  11 12 13 14 15 16 17 18 [19] 20   next >   >>
Login
RE: All Composite 1/7th P-40E Mould Build - 10/18/2012 1:56 AM
Slow Low
Score: 100
Last Login: 5/25/2013
Status: offline
Still have some clay to clean, and my registration pads didn't release again, but all in all not bad for a disabled guy in his basement I suppose.
_____________________________
From possibility to actuality.
http://www.zazzle.ca/two_bulldog_brand*
Hide Signatures
(in reply to Slow Low)
       Post #: 451
RE: All Composite 1/7th P-40E Mould Build - 10/20/2012 3:33 AM
Slow Low
Score: 100
Status: offline
and now we wait...any and all laminating resin donations will be accepted with open arms and the greatest of gratitude at the following address...lol
Two Bulldog P40 Headquarters
94B Henry Street
Brantford, ON
Canada
N3S 7J5
Hide Signatures
       Post #: 452
RE: All Composite 1/7th P-40E Mould Build - 10/20/2012 9:40 PM
Slow Low
Score: 100
Status: offline
many thanks to all of you that offered to move the project forward...and awwaaay we go...
Hide Signatures
       Post #: 453
RE: All Composite 1/7th P-40E Mould Build - 10/21/2012 9:39 PM
Slow Low
Score: 100
Status: offline
If you drop by the shop for a coffee, I'll put you to work... lol
Next, the lower centre section will be cast separate from the remaining two leading edge sections.
Hide Signatures
       Post #: 454
RE: All Composite 1/7th P-40E Mould Build - 10/22/2012 12:56 AM
Slow Low
Score: 100
Status: offline
Someone who no longer needed it, shipped me one of these today.  Top Flite Part Number TOPA1774
I promise to give it a good home and I can't wait to have a look.
Hide Signatures
       Post #: 455
RE: All Composite 1/7th P-40E Mould Build - 11/9/2012 4:37 AM
Steve Westphal
Score: 100
Status: offline
Slow Low.....You have come to the right place. The folks(men and women)at RCU are the best. If they can't answer a question....there is no answer!! This bunch is simply great! They have helped me out tremendously and I thought I knew everything!!! Stick with 'em!!
Steve Westphal
Hide Signatures
       Post #: 456
RE: All Composite 1/7th P-40E Mould Build - 11/25/2012 2:27 AM
Slow Low
Score: 100
Status: offline
Normal0 oNotOptimizeForBrowser />
Spent some time organizing my new work area and got a good jump on the next mould section today.  The rest of the basement is clear and I hope to put some work stations along the walls to support kit production, should the project ever evolve that far.
Hide Signatures
       Post #: 457
RE: All Composite 1/7th P-40E Mould Build - 11/26/2012 12:24 AM
SCALECRAFT
Score: 119
Status: offline
Slow, I have used those retracts. They are a pain to link up. I have for my TF P-40, the Robart air rotating retracts that are a very simple install.
Steve
Hide Signatures
       Post #: 458
RE: All Composite 1/7th P-40E Mould Build - 12/1/2012 3:09 AM
Slow Low
Score: 100
Status: offline
Lower Wing Centre Section - Ready To Mould
Fear not my fine flying friends, we march ever closer….J
Hide Signatures
       Post #: 459
RE: All Composite 1/7th P-40E Mould Build - 12/1/2012 6:59 AM
Slow Low
Score: 100
Status: offline
High Wear Resistance Room Temp Surface Coat (150g)
Hide Signatures
       Post #: 460
RE: All Composite 1/7th P-40E Mould Build - 12/2/2012 1:24 AM
Slow Low
Score: 100
Status: offline
I like pictures - hopefully you do to...if not, close your eyes, right....now
Continuous Strand Surface Veil
6 Oz Tape
9 Oz Cloth
West Systems 105 w/slow hardener
Hide Signatures
       Post #: 461
RE: All Composite 1/7th P-40E Mould Build - 12/2/2012 4:12 AM
Slow Low
Score: 100
Status: offline
coming along....
Hide Signatures
       Post #: 462
RE: All Composite 1/7th P-40E Mould Build - 12/2/2012 4:40 AM
countilaw
Score: 219
Last Login: 5/24/2013
Status: offline
Slow,    I love all the pictures,  but they are so  close up,  it's hard to tell what's going on.    Can you back up a little bit?
Frank
It''s a hobby, not a job.
Hide Signatures
       Post #: 463
RE: All Composite 1/7th P-40E Mould Build - 12/2/2012 4:42 AM
Slow Low
Score: 100
Status: offline
Will do.  The lighting could be better in my new cubby hole....
Hide Signatures
(in reply to countilaw)
       Post #: 464
RE: All Composite 1/7th P-40E Mould Build - 12/2/2012 9:13 AM
Slow Low
Score: 100
Status: offline
I’ll let this set up overnight and tomorrow we’ll have just the leading edge sections to go.
Hide Signatures
       Post #: 465
RE: All Composite 1/7th P-40E Mould Build - 12/3/2012 2:24 AM
Slow Low
Score: 100
Status: offline
Removed the clay and formers. Next it's leading edge sections. Got a hand flipping the mould - GTG again
Hide Signatures
       Post #: 466
RE: All Composite 1/7th P-40E Mould Build - 12/7/2012 5:16 AM
Slow Low
Score: 100
Status: offline
hmmmm - is that a light at the end of the tunnel that I see ??
Note that I've overlapped the upper and lower sections to ensure that there is a guaranteed alignment along the leading edge.  If you look even closer you might notice that the inboard overlap is on the upper section while the outboard overlap is on the lower section...if you look even closer you might also notice that the flanges have draft in two planes...if you look still closer you just get bug-eyed (like me)
Hide Signatures
       Post #: 467
RE: All Composite 1/7th P-40E Mould Build - 12/9/2012 6:16 AM
Slow Low
Score: 100
Status: offline
Wings
Now more nights than I remember,
Did I bow to Glory’s charms.
Tonight My Lady smiles on me,
With bread in open arms.
Lo my world breaks open,
Dawning stairs that weren’t there,
Each step built with hand forged nails,
And dirty, unkempt hair.
Now steely arms spread open:
I have earned the right to fly.
The embers glow a quiet orange
As Glory casts my shadow on an ever sun filled sky.
- b1heqh54
...don't know how long this wing mould has taken me, but tonight it no longer matters...
Hide Signatures
       Post #: 468
RE: All Composite 1/7th P-40E Mould Build - 12/10/2012 10:57 AM
Slow Low
Score: 100
Status: offline
Merry Christmas to me...
Tomorrow we look inside.
Hide Signatures
       Post #: 469
RE: All Composite 1/7th P-40E Mould Build - 12/11/2012 2:07 AM
Slow Low
Score: 100
Status: offline
I’ll fix the broken flange pretty quickly, but what you see is what you get.  (prying with a screw still in place)
Everything worked out great !!  (but I have some new ideas for next time&hellip
Enjoy the video.
http://www.youtube.com/watch?v=GXUW5eBjwJA&feature=g-crec-u
Hide Signatures
       Post #: 470
RE: All Composite 1/7th P-40E Mould Build - 12/11/2012 2:37 AM
OldDC
Score: 100
Last Login: 5/16/2013
Status: offline
Hi there Slow Low, hope you don't mind but I've been lurking in the back ground for some time watching your work...............Man my Hat goes off to you, you are doing a wonderful job.
Just watched your video, the wing looks fabulous plus all the other work you have already done.
Congratulations, keep up the great work.
Remember Never Fly Low and Slow!
Hide Signatures
       Post #: 471
RE: All Composite 1/7th P-40E Mould Build - 12/19/2012 6:01 PM
Slow Low
Score: 100
Status: offline
Thank you OldDC
All trimmed up, clean and waxed.
Here's a tip - keep your bench waxed up good.
Hide Signatures
       Post #: 472
RE: All Composite 1/7th P-40E Mould Build - 12/21/2012 2:05 PM
Slow Low
Score: 100
Status: offline
A little dusty and a little worse for wear, I think I might just keep this plug hanging around like the hero it is....what a brave little soul
Hide Signatures
       Post #: 473
RE: All Composite 1/7th P-40E Mould Build - 12/22/2012 4:01 AM
Slow Low
Score: 100
Status: offline
This is the intended configuration of the lower tool during layup.  As you can see, the leading edge will be integral with the lower skin.  I will try one with a spar that straddles the joint between the upper skin and the leading edge.  This may just be enough to make things nice and easy.  If not, then I may later make joggle flanges to bolt to the lower section that would form a glue lip when the joggle flanges were removed prior to final assembly and I will move the spar rearward in the chord.  I expect that I may have to vacuum bag the lower skin just to hold the cloth on the inverted mould face of the upper leading edges.  Worst case they can always be layed up separately and joined to the lower skin while still a little green.  If you look very closely you might see the LED's that I moulded into pockets recessed into the trailing edges at the ailerons.  They are embedded proud of the tool face in a pocket designed to give the pushrod for the ailerons a place to exit the wing.  This should provide nice lighting inside the tool during final assembly - cool or what...lol
Hide Signatures
       Post #: 474
RE: All Composite 1/7th P-40E Mould Build - 1/7/2013 11:24 PM
Slow Low
Score: 100
Status: offline
Happy New Year Everyone !!
...and this year should prove to be an exceptional one
The most common question I get is how much detail do you lose.
My standard answer is don't breath on your plug while you brush on your tool coat.
Here's a few quik pics of the top of the wing mould.
This should ease your fears about losing any detail, but be warned I don't use PVA, only a thorough coat of pure carnauba wax.
Too many pictures you say - too bad
Hide Signatures
       Post #: 475
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.203RCU1
