BOOST BOTTLES DO THEY WORK ?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Car Engines >> Car Nitro & Gas Engines >> BOOST BOTTLES DO THEY WORK ?
Page: [1]
Login
BOOST BOTTLES DO THEY WORK ? - 3/28/2008 10:42:02 PM
phill200566
Status: offline
i have seen these pop on ebay the black bottle with boost written on the side with the yellow coloured pipe what i'd like to know does anyone have any experiance with these and DO they work if they do what gains if any can i expect
       Post #: 1
RE: BOOST BOTTLES DO THEY WORK ? - 3/28/2008 10:53:49 PM
Chris_RC
Status: online
they just make you run leaner
_____________________________
Losi XXX-T MF2~ XXX-NT Sport RTR 2~ Losi Mini-Baja~ Losi XXX Buggy (SOLD)
(in reply to phill200566)
       Post #: 2
RE: BOOST BOTTLES DO THEY WORK ? - 3/28/2008 11:02:32 PM
46u
Status: offline
Not worth the hassle of the money in my opinion. You normally have to drill and tap a hole in your engine case.
Rebel Racing, Sponsored by, Byron Fuel Looking for a new engine sponsor!
(in reply to Chris_RC)
       Post #: 3
RE: BOOST BOTTLES DO THEY WORK ? - 6/23/2008 1:08:16 AM
magnum57
Status: offline
for 40.00 bucks they work great. no kidding great responce and no sputtering at half throttle.
Click to see fullsize image.
Click for fullsize
Click for fullsize
       Post #: 4
RE: BOOST BOTTLES DO THEY WORK ? - 6/25/2008 2:50:30 AM
NitroTherapist
Status: offline
Personally, I think its a gimmick along with the superchargers. If they really gave you a signifigant increase in performance, don't you think we'd ALL be using them??
(in reply to magnum57)
       Post #: 5
RE: BOOST BOTTLES DO THEY WORK ? - 6/25/2008 5:42:40 AM
hkenvy91
Status: offline
quote:
ORIGINAL: NitroTherapist
well said!
kyosho strr,airtronics M8,o.s.speed,jp-3,tilted fuel
(in reply to NitroTherapist)
       Post #: 6
RE: BOOST BOTTLES DO THEY WORK ? - 6/25/2008 9:48:41 PM
magnum57
Status: offline
all i know is i ran my rigs with out and with and there is a difference. i guess the question is how signifigant of and increase in performance is it worth to have these cool looking bottles on your rc and get a lot smoother and faster rc. maybe you dont get how it works. As the engine (any engine) draws fuel and air in through the carb on the intake cycle, the spark plug fires this mixture forcing the piston down and sucks a small amount of air into the carburetor for the next intake cycle. As the piston and crank bottom’s out on the bottom of the cylinder, the piston begins to make its return upward. As this cycle is happening, the piston pushes air back through the carburetor naturally under pressure. This action creates a reverb effect and causes the air / fuel mix to become double rich as by now it is processed TWICE by your carbs fuel jets. Most commonly, this results in rough idle, hesitation, bogging, and the ever-so- frustrating: Sputtering at top end. The reason the sputtering and bogging is happening is because of the double rich mixture. Heavy exhaust smoke, heavy engine loading is often looked at as too much oil / fuel ratio, bad carburetor, etc. While this may be one of those problems, it often is not. Your engine is actually choking itself out with a bad fuel mix! The installation of our Boost Induction Systems™ Boost bottles eliminates this nagging problem. (Hence the location of the inlet) Our Patent Pending Internal Metering System™ Automatically adjusts itself to work with your engines compression and carburetor. Our bottles will eliminate the reverb caused by your pistons return to top dead center (TDC) and remove the double mix! Now, with the bottle installed, operators are now no longer fooled by the double rich mix. This now allows proper adjustability of the carburetor! Tired of sacrificing top end speed for low end? Or low end speed for high? That’s because you have either a double lean mix or a double rich mix. (Rich for high end, low for low end)You cannot have one or the other without a proper intake booster (Boost bottle). The bottles will provide a “Boost” or “Supercharge” effect. It will even out the double mix (either lean or rich) and allow your engine to idle 3–4 times smoother and decrease your engines vibration. try it what can it hurt ???? try a gasser bro and enjoy
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by magnum57 -- 6/26/2008 12:27:38 AM >
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.750RCU1
