RE: 1/7th Scale Composite Warbird P-40E Warhawk Build    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: 1/7th Scale Composite Warbird P-40E Warhawk Build
Page: <<   < prev  6 7 8 9 10 11 12 [13] 14 15   next >   >>
Login
RE: 1/7th Scale Composite Warbird P-40E Warhawk Build - 4/23/2012 7:49 AM
Slow Low
Score: 100
Last Login: 6/17/2013
Status: offline
I've got something cooking tonight - wanna take a guess??
_____________________________
From possibility to actuality.
http://www.zazzle.ca/two_bulldog_brand*
Hide Signatures
(in reply to Slow Low)
       Post #: 301
RE: 1/7th Scale Composite Warbird P-40E Warhawk Build - 4/23/2012 5:12 PM
Slow Low
Score: 100
Status: offline
You guessed it - that's a lower cowl section.
The tool in all rights should have been at least a two piece mould with the forward section pulling straight off the nose.
Don't be fooled by the test part, rather let it convince you of the durability of the materials involved.  I stood on the mould and pulled and twisted that thing with all my might.
Pile it into the ground, dust it off, pop out the dings and stick it back on.
Lets see you do that with an ABS cowl - NOT!!
We conquered the opaqueness issue with a couple of coats of automotive paint in the mould.
So the next fuselage will get brown camo followed by green paint.
Hide Signatures
       Post #: 302
RE: 1/7th Scale Composite Warbird P-40E Warhawk Build - 6/8/2012 7:31 PM
Slow Low
Score: 100
Status: offline
Hide Signatures
       Post #: 303
RE: 1/7th Scale Composite Warbird P-40E Warhawk Build - 10/6/2012 10:27 PM
Slow Low
Score: 100
Status: offline
New shop - new building season
Wing Mould - Section #2
Flooring Laminate
Old Lamp (tubing)
Furniture Sliders
1/4-20 thread inserts
Aluminum T-slot Extrusion
Carnauba Wax
Hold on....here we go again
Hide Signatures
(in reply to fokke)
       Post #: 304
RE: 1/7th Scale Composite Warbird P-40E Warhawk Build - 10/9/2012 6:10 PM
Slow Low
Score: 100
Status: offline
Normal0 oNotOptimizeForBrowser />
These air fittings will be filled with clay and cast in place along with the o-rings.  I'll rough up the OD's with a file first to ensure adhesion.
Inexpensive, yes; effective, time will tell.
Hide Signatures
(in reply to fokke)
       Post #: 305
RE: 1/7th Scale Composite Warbird P-40E Warhawk Build - 10/10/2012 7:17 AM
Slow Low
Score: 100
Status: offline
Clay holds O-ring flat to face. (8 places)
Barbed part ejector port also included in saddle area.
Hide Signatures
(in reply to fokke)
       Post #: 306
RE: 1/7th Scale Composite Warbird P-40E Warhawk Build - 10/16/2012 6:25 AM
Slow Low
Score: 100
Status: offline
well, it better be right 'cause it's kinda permanent...
Hide Signatures
(in reply to fokke)
       Post #: 307
RE: 1/7th Scale Composite Warbird P-40E Warhawk Build - 10/16/2012 7:32 AM
Slow Low
Score: 100
Status: offline
surface veil to prevent the heavier weaves from showing through over time
Hide Signatures
(in reply to fokke)
       Post #: 308
RE: 1/7th Scale Composite Warbird P-40E Warhawk Build - 10/16/2012 7:50 AM
fokke
Score: 100
Last Login: 6/18/2013
Status: offline
Great progres James !
What resine you use? I see that you use glas for poliester .
http://www.fokkerc.com/
Hide Signatures
       Post #: 309
RE: 1/7th Scale Composite Warbird P-40E Warhawk Build - 10/16/2012 10:27 AM
Slow Low
Score: 100
Status: offline
Thanks Rumen - that is continuous strand surface veil - it does not have binder like the chopped strand surface veil and therefore works with epoxy
Hide Signatures
(in reply to fokke)
       Post #: 310
RE: 1/7th Scale Composite Warbird P-40E Warhawk Build - 10/16/2012 5:44 PM
Slow Low
Score: 100
Status: offline
6 Oz Tape - Outer Flange Support
9 Oz Cloth - 1st Layer
Hide Signatures
(in reply to fokke)
       Post #: 311
RE: 1/7th Scale Composite Warbird P-40E Warhawk Build - 10/17/2012 6:33 AM
Slow Low
Score: 100
Status: offline
no point in throwing another $100 in epoxy and cloth at reinforcing this section until I've seen the cavity - if all turns out well, I can always rough it up with a cup wheel on the grinder and lay down a few more layers of heavy cloth
hopefully this will set up enough to remove the forms tomorrow - now we wait....lol
Hide Signatures
(in reply to fokke)
       Post #: 312
RE: 1/7th Scale Composite Warbird P-40E Warhawk Build - 10/18/2012 12:10 AM
Slow Low
Score: 100
Status: offline
These flanges are 2 layers of 9 Oz cloth over the tool coat.
It works well.  The flange is firm, but still somewhat moveable.
Hide Signatures
(in reply to fokke)
       Post #: 313
RE: 1/7th Scale Composite Warbird P-40E Warhawk Build - 10/18/2012 1:58 AM
Slow Low
Score: 100
Status: offline
Still have some clay to clean, and my registration pads didn't release again, but all in all not bad for a disabled guy in his basement I suppose.
Hide Signatures
       Post #: 314
RE: 1/7th Scale Composite Warbird P-40E Warhawk Build - 10/20/2012 3:35 AM
Slow Low
Score: 100
Status: offline
and now we wait...any and all laminating resin donations will be accepted with open arms and the greatest of gratitude at the following address...lol
Two Bulldog P40 Headquarters
94B Henry Street
Brantford, ON
Canada
N3S 7J5
Hide Signatures
(in reply to fokke)
       Post #: 315
RE: 1/7th Scale Composite Warbird P-40E Warhawk Build - 10/20/2012 9:42 PM
Slow Low
Score: 100
Status: offline
many thanks to all of you that offered to move the project forward...and awwaaay we go...
Hide Signatures
(in reply to fokke)
       Post #: 316
RE: 1/7th Scale Composite Warbird P-40E Warhawk Build - 10/21/2012 9:40 PM
Slow Low
Score: 100
Status: offline
If you drop by the shop for a coffee, I'll put you to work... lol
Next, the lower centre section will be cast separate from the remaining two leading edge sections.
Hide Signatures
(in reply to fokke)
       Post #: 317
RE: 1/7th Scale Composite Warbird P-40E Warhawk Build - 10/22/2012 12:58 AM
Slow Low
Score: 100
Status: offline
Someone who no longer needed it, shipped me one of these today.  Top Flite Part Number TOPA1774
I promise to give it a good home and I can't wait to have a look.
Hide Signatures
(in reply to fokke)
       Post #: 318
RE: 1/7th Scale Composite Warbird P-40E Warhawk Build - 10/22/2012 9:13 PM
rvaflyer
Score: 100
Last Login: 4/19/2013
Status: offline
 hey there slow low,
are you still using the Aeropoxy PT-1414 as your first layer of tooling epoxy, then using the Miapoxy as a 2ng layer and finishing with the WestSystem 105? im ready to start my moulding process and ive been following you for a long time. Now im ready to pull the trigger on my own project but need some clarity on the products/steps.your help is greatly appreciated.Thanks ,rvaflyer
Hide Signatures
       Post #: 319
RE: 1/7th Scale Composite Warbird P-40E Warhawk Build - 11/25/2012 2:29 AM
Slow Low
Score: 100
Status: offline
Spent some time organizing my new work area and got a good jump on the next mould section today.  The rest of the basement is clear and I hope to put some work stations along the walls to support kit production, should the project ever evolve that far.
Hide Signatures
       Post #: 320
RE: 1/7th Scale Composite Warbird P-40E Warhawk Build - 12/1/2012 3:12 AM
Slow Low
Score: 100
Status: offline
Normal 0 oNotOptimizeForBrowser/>
Lower Wing Centre Section - Ready To Mould
Fear not my fine flying friends, we march ever closer….
Hide Signatures
       Post #: 321
RE: 1/7th Scale Composite Warbird P-40E Warhawk Build - 12/1/2012 7:00 AM
Slow Low
Score: 100
Status: offline
High Wear Resistance Room Temp Surface Coat (150g)
Hide Signatures
(in reply to fokke)
       Post #: 322
RE: 1/7th Scale Composite Warbird P-40E Warhawk Build - 12/2/2012 1:26 AM
Slow Low
Score: 100
Status: offline
I like pictures - hopefully you do to...if not, close your eyes, right....now
Continuous Strand Surface Veil
6 Oz Tape
9 Oz Cloth
West Systems 105 w/slow hardener
Hide Signatures
(in reply to fokke)
       Post #: 323
RE: 1/7th Scale Composite Warbird P-40E Warhawk Build - 12/2/2012 4:15 AM
Slow Low
Score: 100
Status: offline
coming along....
Hide Signatures
(in reply to fokke)
       Post #: 324
RE: 1/7th Scale Composite Warbird P-40E Warhawk Build - 12/2/2012 9:14 AM
Slow Low
Score: 100
Status: offline
I’ll let this set up overnight and tomorrow we’ll have just the leading edge sections to go.
Hide Signatures
(in reply to fokke)
       Post #: 325
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.766RCU1
