Discussion - New Bantam BC6 reaching temps of 113F while charging
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> Common Sense RC Support >> Discussion - New Bantam BC6 reaching temps of 113F while charging
Page: [1]
Login
Discussion - New Bantam BC6 reaching temps of 113F whil... - 3/29/2008 7:17:38 AM
!bungle
Status: offline
I purchased a Bantam BC6 new at my LHS and while it seems to be working properly, I've noticed that it gets very hot during the charging process. I'm charging 6cell Team Orion 4500Mah RocketPack NiMh packs that have TRX connectors and my charger is connected by banana plugs, 16 gauge silicon wire, and TRX connectors. The charge rate is 4.5A. The temps of the metal case are reaching 113F. This is in a well-ventilated room with an ambient temp of 76F and the charger is on its rubber feet on a smooth hard surface with no vents blocked.
Question is, should I be worried?
Dirk
       Post #: 1
RE: Discussion - New Bantam BC6 reaching temps of 113F... - 3/31/2008 11:46:19 PM
Tram
Status: offline
I do not know the answer, but I know who will.. I'll show him this link..
Jeff
www.CommonSenseRC.com
_____________________________
Jeff Williams
(in reply to !bungle)
       Post #: 2
RE: Discussion - New Bantam BC6 reaching temps of 113F... - 3/31/2008 11:52:41 PM
RC Accessory
Status: offline
Hi Dirk,
The unit will get warm to slightly hot depending on the amperage being charged. I will set one up here at the shop and see how hot it gets. My larger nicad packs are 2400 8 cell packs, but I can charge them a rate to equal the 33 watts you are outputing.
RC Accessory, Inc
Auth US Bantam Importer
(in reply to Tram)
       Post #: 3
RE: Discussion - New Bantam BC6 reaching temps of 113F... - 4/1/2008 1:44:39 AM
!bungle
Status: offline
My thanks for your reply...
It's my understanding that the BC6 has no cooling fan and that the aluminum case is going to act as a heatsink to a certain extent. I just want to make sure I'm not approaching temperature levels that I shouldn't be. I may want to use this charger trackside this summer and I live in Texas - and it gets pretty hot here. I plan to purchase a pair of 7cell 4600Mah NiMh side-by-side packs in the near future followed by a pair of 5000 or 8000Mah LiPo packs later on, so I may be charging at rates closer to (and possibly including)5A for even longer periods of time.
Dirk
(in reply to RC Accessory)
       Post #: 4
RE: Discussion - New Bantam BC6 reaching temps of 113F... - 4/1/2008 10:17:54 PM
supi7
Status: offline
The BC6's components are using the metal body as a Heat Sink.
the board itself has 2 Regulators that are in direct contact with the bottom plate.
Charging at high rate will get the regulators pretty hot but its normal, the Heat sink is doing its job, nothing to worry about.
Best Wishes,
Dan
TrueRC
}Z)2[S-+Q-qO7{.WLlPgw6}Y;U]26(qO7XeS's]m(pU{.{dw6DrW:T(;LzL,n[7HdDf6,WW )LBnRmZa
       Post #: 5
RE: Discussion - New Bantam BC6 reaching temps of 113F... - 4/1/2008 11:44:30 PM
!bungle
Status: offline
The direct contact explains the temps getting a bit high, so I'll try to stop worrying... It's just that at 113F it's hot enough to not want to touch it! I'm assuming the plastic touch-sensitive keypad & the LCD screen can deal with these temps?
(in reply to supi7)
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.733RCU1
