YA F-18 Owners, side rail and steering solution
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Jets >> YA F-18 Owners, side rail and steering solution
Page: [1] 2 3   next >   >>
Login
YA F-18 Owners, side rail and steering solution - 3/29/2008 10:32:22 PM
seanreit
Status: offline
Here's the long awaited solution, upgraded side rails that come ready to fit and steering arm solution.
$100.00 for the side rails, $30.00 for the steering arm. Plus shipping.
Buck, this is yours and it will go out early next week, and Billy, your order is complete, let me know if you want the steering arms.
PS, this is mocked up, the set screws will be flush when we get them.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 1
RE: YA F-18 Owners, side rail and steering solution - 3/29/2008 10:36:02 PM
seanreit
Status: offline
Joe, the rail the plastic bushing rides in on yours has been slightly modified, let me know if you want to upgrade. Special price for you bud.
(in reply to seanreit)
       Post #: 2
RE: YA F-18 Owners, side rail and steering solution - 3/29/2008 10:50:54 PM
cactusflyer
Status: online
Very nice work Sean! You are truly becoming a Jedi!
Tailwinds,
John
_____________________________
Tamjets rep, Not a Wren rep...........Just a very satisfied customer!"
www.jetsnstuff.com
       Post #: 3
RE: YA F-18 Owners, side rail and steering solution - 3/29/2008 10:59:20 PM
SDCrashmaster
Status: online
Nice work Sean. That sure looks like a solid solution.
In looking at your photos, I need to shout out to all those who have, or are waiting on gear detail from me...the steering arm that Sean shows above will interfere with the detail work on the nose gear.
My upper detail sleeve goes up halfway between the two set screws that secure the pin in the top of the nose strut. Just a head up.
The top of the sleeve almost reaches the side rails. (see pic)
Paul
Click for fullsize
Yeah, I use mixing... Balsa & Dirt. ©
       Post #: 4
RE: YA F-18 Owners, side rail and steering solution - 3/29/2008 11:04:22 PM
seanreit
Status: offline
Paul, can there be a solution based on your work to integrate the solution Joe came up with? If so, how would you propose to do it?
Can you draw an idea up?
(in reply to SDCrashmaster)
       Post #: 5
RE: YA F-18 Owners, side rail and steering solution - 3/29/2008 11:34:01 PM
SDCrashmaster
Status: online
Not sure without seeing exactly where you have positioned your tiller arm.
It appears you're only contacting the aft circumference of the strut. It may be possible to remove a upper rear section of my upper detail sleeve to facilitate using that tiller arm.
Overall shortening the sleeve to only go up to the tiller arm would not look good at all. It's already marginal from a scale "ground level" angle (as far as the detail dissapearing up into the well).
Might not be as noticeable if the front of the detail work was still there.
The upper detail tube must slide down from the top during assembly (along with the uppermost retaining ring with set screw), so the tiller arm would have to remain detached until the last step.
The reason it all has to slide from the top down is because the struts very lower end is painted, and that paint thickness will not allow any of the components to slide on from the bottom.
The tolerances are so tight that even the smallest deformations to the strut from set screws, burring from the retainer rings set screw bores, etc. immediately inhibit the free movement of the components up and down the shaft. This is such a probelm that I have lately been painting the nose strut and detail fully assembled.
Can you post a pic of the arm area close up, in relation to the two set screws it the top aft end of the strut? Does your strut rotate 180˚ in the trunion, or are you still utilizing the stock tillers as an anti-rotation device?
The further I look at your pics, I'd say that the detail going up only as far as the base of your tiller appears the only solution.
Long windidly yours ,
Paul
       Post #: 6
RE: YA F-18 Owners, side rail and steering solution - 3/29/2008 11:53:10 PM
yeahbaby
Status: online
awesome
       Post #: 7
RE: YA F-18 Owners, side rail and steering solution - 3/30/2008 12:02:14 AM
Billy
Status: offline
Nice job Sean!!! Count be in on the steering arm too. Can it be welded on or is the set screw thing pretty strong? I will collect the rest of the guy's money next weekend. I'll send you the check then. Thanks for all the work you put in.
Hey what size are the holes in the arm? Is there enough meet to tap a 10/32?
Billy
(in reply to yeahbaby)
       Post #: 8
RE: YA F-18 Owners, side rail and steering solution - 3/30/2008 12:36:44 AM
seanreit
Status: offline
It's double tapped 4-40 right now. I gave it the ole hand pull test and it was pretty stout. If you want to increase it later, my all means, go ahead, but I'm pretty happy with it myself, if it was mine, I'd fly it.
(in reply to Billy)
       Post #: 9
RE: YA F-18 Owners, side rail and steering solution - 3/30/2008 1:28:44 AM
Joe McBride
Status: online
Nice job Sean! Paul, from your pictures and Sean's it doesn't look like a conflict. It looks like the tiller arm can be "set" comfortably above the scale piece you make.
Joe
Team JR ~ Fromeco ~ Desert Aircraft ~ RCU
www.joemcbride.com
       Post #: 10
RE: YA F-18 Owners, side rail and steering solution - 3/30/2008 1:51:21 AM
SDCrashmaster
Status: online
It looks that way but, upon retraction, my detail work is only 1 millimeter from the side rails.
I can't really tell exactly where he has them in the pics, but on the detail work, I have an access hole about 1/8" below the top edge of my upper tube to access the lower of the two upper pin set screws.
In studying his pics closer, it may not be as intrusive as I thought...might only require cutting of the top 1/8"-1/4" of the detail.
Also, Sean's pic looks like Gen1 gear based off of the oleo (like your first ones Joe) so I may be looking at oranges and comparing my apples to them.
P
(in reply to Joe McBride)
       Post #: 11
RE: YA F-18 Owners, side rail and steering solution - 3/30/2008 3:39:32 AM
scaleMan
Status: offline
from Sean's pictures and looking at my nose gear, it sure looks like it will fit on there without modification..... Id like to get a set made up for my nose gear Sean if possible... thx Greg
       Post #: 12
RE: YA F-18 Owners, side rail and steering solution - 3/30/2008 3:50:49 AM
seanreit
Status: offline
PM me for orders if you don't mind, and I'll get anyone set up.
(in reply to scaleMan)
       Post #: 13
RE: YA F-18 Owners, side rail and steering solution - 3/30/2008 5:00:57 AM
Boomerang1
Status: offline
Lovely job! Is the steering arm designed for a mechanical linkage or cables? - John.
Distributor for: Nothing! So my posts can be unbiased.
       Post #: 14
RE: YA F-18 Owners, side rail and steering solution - 3/30/2008 5:10:43 AM
seanreit
Status: offline
Only cables, if anyone wants to invest in direct drive for this airplane, please let me know, I have at least one option for less than $250.00 that is very robust.
(in reply to Boomerang1)
