LDM
yes , for more clarity if you were to build a P40 --example the 64" Top Flight P40 , you will find the fuse of the 70" CMP P40 to be much lighter .While this is one of the best CMP planes to date as far as quality , the CMP type fiberglass is very light weight and will be subject to the "tin can "effect , defined as -if you pick it up in an area where there is no wood internal support , you will feel the fuse flex . I used "flite skin" inside the fuse to support the weaker areas just because I am not a fan of a 4 stroke 180 size plane that has flex in the structure of the fuse . I am buildind the CMP Fw190 at this time and doing the same thing to areas of the fuse that I can reach . I will be useing a G26ei , however this plane is very easy to mount the G26 due to the firewall install being straight up . Also the Fw190 has a history of needing major nose weight to achiev CG , so I figured to add weight in the engine size first . The CMP P40 has a solid wood ply rail running from the front end to the first and secend internal fuse supports , this can be seen on there website , converting to gas requires a cutting this area , adding a traditional vertical bulkhead with major 90 degree supports .Its been done by a guy in Aust and is posted in the lenghthy post on this plane If you choose the saito 180 , its alreday tapped for a fuel pump , and it installs upside down with no problems at all , very well worth the money . The G26EI will be my second gas engine , based on adding another battery to be charged when I need to fly for the EI , I am still in limbo of the benifits if gas engines vs a nice 4 stroke , savings in gas has never been a concern with me because I am a weekend flyer .
_____________________________
LDM
