Giant scale electric power with A123's
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> A123Racing Support >> Giant scale electric power with A123's
Page: [1]
Login
Giant scale electric power with A123's - 3/30/2008 3:58:54 AM
marc 540
Status: offline
Is it possible to run A123's instead of li-po's to power giant scale outrunner engine's? I'm thinking about converting my 50cc gasser to electric but li-po's are very $$$!!
Thank's Marc 540
       Post #: 1
RE: Giant scale electric power with A123's - 3/30/2008 4:17:36 PM
everydayflyer
Status: offline
Of course you can. Years ago some rather large aircraft were converted to electric using motors from cordless power tools and Nicd batteries. These motor were far heavier and less efficient than modern brush-less motor and the Nicds were also much heavier.
During the past few years there has been a LiPo mania epidemic and everyone seems to this that LiPolys are the only viable power source for electric flight.
I flew many .40 size aircraft with 4 and 5 cell A123 2300 mAh batteries. One is a Sig Fazer which had an OF .46FX with tuned pipe and ran a 12X4 prop. It now has an AXI 2826-12 5S A123 and APC 13X6.5E prop. It in fact weighs almost 12 oz. less and has better power then it did when glow powered. AUW is 4 1/2 pounds and it has just over 600 watts of power.
A good site to do a little research is
http://homepage.mac.com/kmyersefo/M1-outrunners.htm
Here is aan interesting Thread on RC Groups
http://www.rcgroups.com/forums/showthread.php?t=722914
Charles
< Message edited by everydayflyer -- 3/30/2008 6:21:21 PM >
(in reply to marc 540)
       Post #: 2
RE: Giant scale electric power with A123's - 4/4/2008 3:03:41 PM
Walt Thyng
Status: offline
How does a 1/4 scale Reno racer biplane with a MagaMax and 12 A123s on a 16/12 prop sound. Is that giant scale enough> Or a Nosen Citabria on a geared Astro 60 with 32 NiMhs? Cobra is 19lbs rtf, cit is 17lbs rtf. Cobra has been radared at 85mph (scale would be about 66 mph).
sorry, I don't know how to post pics to this forum yet.
Walt
_____________________________
WT in Illinois
(in reply to everydayflyer)
       Post #: 3
RE: Giant scale electric power with A123's - 4/6/2008 1:21:32 AM
dirtybird
Status: offline
Here is a couple of pics of my installation in a Nitroplanes 80" Extra. I just took two Dewalt packs and removed the case and hung them on the firewall. The motor is a Hacker 6016 and turns a 20x10 prop at 5700 on the batteries. The longest flight I have had so far is 4 minutes after which I charged each pack 1 AH. At that rate I should get 8 minutes and still have power to land. The Extra landing gear need beefing up to withstand the extra 2lb of the electric conversion.
The airplane weighs 17lb resulting in 37 oz/sq ft wing loading. With 15 lb max thrust it seems to fly OK but its not good for 3D. I would rather fly like an airplane than flit around like a butterfly anyway.
Click to see fullsize image.
Click for fullsize
Click for fullsize
(in reply to Walt Thyng)
       Post #: 4
RE: Giant scale electric power with A123's - 4/6/2008 11:05:12 PM
dick Hanson
Status: offline
Here is my latest approach:
I have a couple of "60" size motors One is the EFlite -the other a similiar sized one from Extreme Flite .
I started setting up a little YAK from Seagull -65 " thing - anyway -I put in the EFite 60 and new 60 EFlite controller
and figgered on 7 cells - pushing the limit on VOLTAGE for the ESC
After sme cogitating and discusion with a friend who is running 16 A123 in series (yes series) on a geared Nue -- I decided to ge another ESC which would allow more voltage
NOT more amps -mor voltage --so I got a Cyclon 80 HV - good for 40 volts (these are on blow out at Horizon for 101 bucks a steal as list was 300 bucks
Now I am going to use th little YAK as a mule to try 8cells on th e 60 -thats almost 29volts starting voltage --which will smoke a 24 v ESC
I will have to fiddle to get best prop size for this 23 oz pack but I thinkit will all work out .
I am shooting for --40 amps with whatever the prop prooves out to be -
I am looking for lower amps more volts -cooler running-andbased on others reults it looks feasable
charging is easy - I have both 8 and 4 volt chargers and I will build two 4 cell packs connected in series with the EFight Y.
I am watching you ----
Libby
(in reply to dirtybird)
       Post #: 5
RE: Giant scale electric power with A123's - 4/7/2008 1:50:34 AM
dirtybird
Status: offline
If you look closely at the pictures you will note I have the plastic inner holders from the Dewalt packs still on the packs. This allows me to check each cell voltage. After about ten recharges I have not had to rebalance. I have not yet run them more than about 50% discharge.
My charger is nothing more than a full wave rectifier connected to a variac and powered by a 1K Pep Boys generator. For a filter I have an automobile noise filter and a 4700uf capacitor I got from Radio Shack. It reduces the ripple to about 2V P-P. I can charge up to 25 Amps with this. I just watch the voltage and quit at 37 volts. Since it usually only takes 10 minutes its no problem.
I got the batteries from Ebay for $170, the motor from Viper hobbies for $75 (show special) and the ESC from Hyperion for $185. Thats less than the ZDZ 40 the airplane is designed for.
The Hyperian ESC is good for 12 Lipolys so I could go up to 14s2p if I need more power and get longer flight times if I wanted to. I have plenty for me as it is.
(in reply to dick Hanson)
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.547RCU1
