MODE C Transponders and altimeters.
Tower Hobbies
Logged in as Guest
  Printable Version
Mustang Exhaust - Kit
Seller:  tony-howard
Details:   $35.00   |  7/5/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> Full Scale planes, cars, helis, boats >> Airplanes - Full Scale >> MODE C Transponders and altimeters.
Page: [1]
Login
MODE C Transponders and altimeters. - 3/30/2008 4:43:50 PM
Kaoma
Status: offline
A MODE C Transponder transmits to the tower among other info, the ALTITUDE of the plane. If the altimeter does NOT have a data port in the back (is not ENCODING) and all it has is the static tube fitting, how does the Transponder gets the altitude of the plane?. At my home base is a Cessna 172 that was banged pretty bad and it was dissasembled for parts. The Altimeter did not have any data port on the back, but still the plane was fitted with a MODE C Transponder...I am lost now.
_____________________________
Danny Condruti
AMA: 805492, CAP: 437366
       Post #: 1
RE: MODE C Transponders and altimeters. - 3/31/2008 2:30:13 AM
culver
Status: offline
Somewhere under the panel there is mounted a box called a blind encoder. It takes static pressure and turns it into a signal that is put out through the transponder as an altitude reading. Look for a connector from the back of the transponder mounting tray to a box that is connected to static pressure and that will be the encoder.
(in reply to Kaoma)
       Post #: 2
RE: MODE C Transponders and altimeters. - 4/1/2008 5:11:36 AM
Kaoma
Status: offline
Got it, thanks. One more question,...then what is the data port on the back of the Altimeter (encoding) for?...auto pilot?
Danny Condruti
(in reply to culver)
       Post #: 3
RE: MODE C Transponders and altimeters. - 4/10/2008 4:44:17 PM
culver
Status: offline
The data port on an encoding altimeter connects to the transponder.
(in reply to Kaoma)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.344RCU1
