HighPlains
KS, USA Status: offline
I put my Pickett slip stick away years ago, for an HP 45. Damn thing cost me as more than my Kraft KP-4 SS radio. That's single stick, not spread spectrum. Deltas are slow, but their saving grace is that they are easy to land. But if you are using gravity to add power, you lose efficency when you have to pull out. If you look at the results of the German speed events from a couple of years ago, you will find that the pylon based 6.5cc powered model topped out at 208 mph. The 15cc only did about 226 mph with 2.3 times as much displacement. If the engine power output is somewhat proportional to displacement, then I would have expected at least double the power with the larger engine. That should have been enough to push a plane with simular drag to over 260 mph. So you can conclude that either the larger engine just is not making the power, or the drag of the airframe was much higher than the racer. The pylon ship has a very high aspect ratio wing, so it will maintain the dive speed better though the traps.
_____________________________
"Pay no attention to the man behind the curtain"
