Eindecker Swirl Pattern on Cowl
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Scale Aircraft >> Eindecker Swirl Pattern on Cowl
Page: [1]
Login
Eindecker Swirl Pattern on Cowl - 3/30/2008 10:02:22 PM
phatbob02
Status: offline
I'm building the Balsa USA Eindecker 40. Somewhere on the web I saw a process for creating the swirl pattern on the cowl using a paint method. Anyone heard of this?
Bob
       Post #: 1
RE: Eindecker Swirl Pattern on Cowl - 3/30/2008 10:35:15 PM
sylvaner
Status: offline
I haven't seen anything on a paint method, but I have used steel wool in an electric eraser. I suppose that you could also use a Dremel on low RPM.
The results lok great.
(in reply to phatbob02)
       Post #: 2
RE: Eindecker Swirl Pattern on Cowl - 3/31/2008 12:12:03 AM
abufletcher
Status: online
I've seen the random scroll pattern done in aluminum powered-based paint. It looks very convincing. When I did my EIII I borrowed an electric eraser. The key is to practice A LOT before you start in on your model. I bought a few $1 store aluminum pans to practice on. What finally worked for me was to use short 2-3 second bursts, not paying much attention to the shape of the swirls, and just go for a certain density of swirls in a given space.
(in reply to sylvaner)
       Post #: 3
RE: Eindecker Swirl Pattern on Cowl - 3/31/2008 8:42:46 AM
camdyson
Status: offline
Paints like Humbrol Metalcote or other metal-based paints can be selectively polished using a buffing bit in a Dremel. I've heard varying reports about trying to clear-coat these paints though (most bad!) so suggest practice technique AND clearcoat on a scrap first. Good luck,
Cam
(in reply to abufletcher)
       Post #: 4
RE: Eindecker Swirl Pattern on Cowl - 3/31/2008 9:30:32 AM
pilotorc4
Status: offline
I replaced my cowl with an aluminum kitchen pot I found at the grocery store, the diameter was close enough, then I used a dremmel with a small steel brush to simulate the swirls.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 5
RE: Eindecker Swirl Pattern on Cowl - 3/31/2008 4:00:31 PM
mogman
Status: offline
For "engine turning" I use a pencil in a drill press and with light pressure the eraser makes very convincing swirls. Just buy lots of pencils
Cheers, Dave.
(in reply to pilotorc4)
       Post #: 6
RE: Eindecker Swirl Pattern on Cowl - 3/31/2008 5:40:07 PM
red1
Status: offline
Pilotorc4,
If I am not mistaken, that is a Henschel Hs 123 in Spanish insignia on your post. May I ask why you chose that particular A/C? Have you built one? I have the plans and intend to build one in the near future. Just curious. One doesn't see this aircraft depicted too often.
red 1 (aka Don Borton)
AMA IMAA
WACO Brotherhood #72
       Post #: 7
RE: Eindecker Swirl Pattern on Cowl - 3/31/2008 6:21:13 PM
pilotorc4
Status: offline
Red1 you are correct, I have a set of plans from graham which is 80 some inche wingspan, I just ordered a kit from a guy in the states so I can build it when I get back, I think the HS 123 is one of the best looking biplane warbirds.
(in reply to red1)
       Post #: 8
RE: Eindecker Swirl Pattern on Cowl - 3/31/2008 7:39:27 PM
red1
Status: offline
If you haven't seen it, look at Post 44, "Let's See Your Luftwaffe Birds", RC Warbirds & Warplanes (Tommie, Hereford, TX).
       Post #: 9
RE: Eindecker Swirl Pattern on Cowl - 4/1/2008 10:28:09 PM
fledermaus
Status: offline
Getting back to the original topic (aluminum swirls) the article phatbob was thinking of was in Model Airplane News and it appears in Volume 1 of the two "Radio Control Airplane How To's" books they published. The article title is "Authentic Aluminum". I don't have my copy with me (I'm wasting time at work) but as I recall the gist of it was:
Pre-coat the wood surface with butyrate dope. Sand smooth. Mix fine aluminum powder with butyrate dope to get a thick but smooth paste. Apply the paste to the doped surface. Sand, recoat. Then, using a soft balsa stick 1/4 sq in a drill, and moistening with a small amount of thinner, burnish with the tip of the stick to get the swirl effect.
Edited later: the article was by Clarke Smiley and appeared on pages 44-45 of the How To's Volume 1.
< Message edited by fledermaus -- 4/2/2008 3:05:01 AM >
(in reply to red1)
       Post #: 10
RE: Eindecker Swirl Pattern on Cowl - 4/2/2008 7:34:56 AM
JohnF
Status: online
Bob, You need to check out the SR batteries web site. They have a step by step way to make the finish using aluminum boiler tape. Here's the way it really looked. Not really sworls.
Click for fullsize
Click for fullsize
(in reply to fledermaus)
       Post #: 11
RE: Eindecker Swirl Pattern on Cowl - 4/2/2008 1:01:09 PM
BRITTURB
Status: offline
John F
Could you PLEASE send me any other pictures that you have of the Eindecker!!
I am having a reallly hard time finding referance pictures.
I am trying to detail a Balsa USA 90.
Any help is greatly appreciated!!!
Britt
(in reply to JohnF)
       Post #: 12
RE: Eindecker Swirl Pattern on Cowl - 4/5/2008 3:09:30 AM
JohnF
Status: online
Britt, Go to www.theaerodrome.com and ask for help with the Eindecker. I am sure you will be pleased with the response. I don't have anything else to share on this one.
(in reply to BRITTURB)
       Post #: 13
RE: Eindecker Swirl Pattern on Cowl - 6/29/2008 6:03:25 PM
phatbob02
Status: offline
Well I finally did it. I used the SR Battery method. It came out nice for a fun scale plane. I bought a Fiberglass Specialties cowl and SR's aluminum sheet tape. Thanks guys.
Click for fullsize
Click for fullsize
< Message edited by phatbob02 -- 7/4/2008 2:17:15 PM >
(in reply to JohnF)
       Post #: 14
Page:   [1]
Page: [1]
Jump to:
